Old 03-31-2011, 01:19 PM   #1
4matty3
4matty3's Avatar
master cylinder question
there is only brake fluid in the front section of my cylinder. is it suppose to be filled up in the back section too?
1971 c10
4matty3 is offline   Reply With Quote
Old 03-31-2011, 01:20 PM   #2
Katrina/10
Katrina/10's Avatar
Re: master cylinder question
Yes, there is!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-31-2011, 01:28 PM   #3
4matty3
4matty3's Avatar
thank you! hopefully that is the reason why my brakes are so soft. (sorry for the rookie question)
1971 c10
Old 03-31-2011, 01:29 PM   #4
bundeber
One reservoir is for front brakes and the other is for the rears.... My guess is you have a leak somewhere. This is designed this way so that if you do have a leak, which it appears you do, you still have one set of brakes to stop you.
bundeber is offline   Reply With Quote
Old 03-31-2011, 01:44 PM   #5
4matty3
4matty3's Avatar
ok thank you. the rear didnt have any fluid in it at all and when i hit the pedal it goes straight to the floor. now what?
1971 c10
Old 03-31-2011, 01:59 PM   #6
HARJO
HARJO's Avatar
Grab a buddy to help bleed the brakes. Start with the farthest from the master cylinder, work to the closest. If you're really really new to working on stuff, there are some quick how-to's on youtube.
1968 Chevy C10:
4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc.
HARJO is offline   Reply With Quote
Old 03-31-2011, 03:43 PM   #7
cdowns
cdowns's Avatar
in that case your brake warning light should b coming on
try bleeding them but more than likely you have a leak and wood need to find and repair
Old 03-31-2011, 04:13 PM   #8
dads longhorn
dads longhorn's Avatar
The pedal pressure in my 1971 was unreliable to the max. One time the brake light did come on. (Both resevoirs (sp) had fluid though)Took it in and got a new master cylinder, The mechanic said rebuilt master cyc are unreliable. drain all lines, refill. So far so good. FYI
dads longhorn is offline   Reply With Quote
