Old 03-31-2011, 02:36 PM   #1
rsavage
rsavage's Avatar
Replacement Valve Cover Grommets
Just as an FYI, if you need replacement stock valve cover grommets they can be had at your local NAPA. Not listed for our trucks but work perfectly. The larger one NAPA Balkamp PN 703-1302 is for the oil fill tube and the NAPA PN 630-1038 is for the breather hose end (from the carb spacer) and the PCV valve.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-31-2011, 04:45 PM   #2
lt704
Re: Replacement Valve Cover Grommets
thanks for the info Rsavage, the truck needs a new one....Russ
lt704 is offline   Reply With Quote
