Old 03-31-2011, 04:21 PM   #1
mrwill17
1 Ton Brake problems
I have an 1985 GMC Sierra 3500 with a Dana 60 and Bendix brakes. The problem I am having is that I cannot get the caliper off. I removed the only hex bolt and banged on it to shake it loose but not luck. If there is a trick to get the calipers off let me know. Thanks everyone!!!
mrwill17 is offline   Reply With Quote
Old 03-31-2011, 10:30 PM   #2
Gyawo
Re: 1 Ton Brake problems
Crack the bleeder screw, see if there is still pressure being held in the caliper. I do not know what the calipers look like, but usually there are two slider bolts and two bracket bolts, are you trying to get just the caliper off or the caliper and bracket? If a caliper(still attached to the bracket) is giving me a problem I usually try prying between the rotor and caliper with a screwdriver.
Gyawo is offline   Reply With Quote
Old 04-01-2011, 09:38 AM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
lol i just had the same issue.
once you get the hex bolt out you need to take comething and gently hamer the slider inwards (the slider is the part that the hex screw was through)
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 04-01-2011, 09:39 AM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
What was the original problem? Was the brake stuck? I've seen the rubber lines going from the caliper to the frame rail wad up inside and not release the pressure to the caliper. Like Gyawo said, loosen the bleeder and see if it helps. Change the rubber line if it looks old.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-01-2011, 10:04 AM   #5
jitteryguy
GoatLube Experss
jitteryguy's Avatar
X2 the wedge is still in it. look at close while it comes out, when you go back together you will swear it wont fit.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 04-01-2011, 10:08 AM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
had that problem too lol
Old 04-01-2011, 10:20 AM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
yep, I know bout it from experience. plus we use to service CUKV's at FtCampbell, every one had trouble with there first one.
'85 1/2 ton CCSB
'92 S10 350/350
