04-01-2011, 02:28 AM | #1 |
help with rear end choice
what type of rear end would be best to put in my 1985 chevy long wheel base . it has original rear end but want posi rear . has a 350 4bolt main with 350 tranny . any suggestions
04-01-2011, 02:32 AM | #2 |
Re: help with rear end choice
04-01-2011, 02:58 AM | #3 |
You've prob got a stock 10-bolt. It's a good enough axle for what you have. Just put in the ratio you want & add some kind of Posi set-up if it's in your budget. Other than that just change the fluid & replace the axle shaft seals & you'll be good!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
04-01-2011, 09:29 PM | #4 |
tyvm
04-01-2011, 10:23 PM | #5 |
If it was me I'd use the original 10 bolt but add a posi out of a 8.5 10 bolt car such as a Caprice or 70's Camaro. They are a lot better than the gov-lock that was offered from the factory in a 85 1/2 ton.
04-01-2011, 10:46 PM | #6 |
Rockwell...
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic. |
