04-01-2011, 11:44 AM | #1 |
umm, explain this bag kit to me
http://www.performanceonline.com/197...N-KIT-ARR7387/ i am guessing this is not for 73-87 ? (no trailing arms) |
04-01-2011, 12:15 PM | #2 |
Re: umm, explain this bag kit to me
That appears to be a pic of a front system.
73-87's will either use an AOL type set-up (removing some leaves & using the bags to replace their capacity) or removing/swapping the leave set-up for a 4-bar.
04-01-2011, 04:33 PM | #3 |
Happy to be here
Scot it looks more like a 67-72 rear kit. No bag plates and long shocks indicate its not a front kit.
04-01-2011, 05:06 PM | #4 |
My guess is that the disclaimer stating that "actual parts may vary from the picture" is missing.
Edit: Yep, the pictures seem to be the same for every kit...
Smoke Tires, not Drugs Last edited by MONTEZ; 04-01-2011 at 05:08 PM. |
04-01-2011, 06:24 PM | #5 |
just as i suspected, i just want you pros to tell me for sure!
