Old 04-01-2011, 01:16 PM   #1
RoyL
RoyL's Avatar
64-66 Blinker Switch, Come complete?
My steering wheel horn/column didn't have parts installed. so not sure what's missing. Hard to tell what comes with the switch from any of the websites who sell. I assume all I need is the switch? Like this one?
http://www.dreamershotrods.com/turns...66chevypu.aspx
Thx,
Roy
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 04-01-2011, 02:00 PM   #2
PGSigns
PGSigns's Avatar
Re: 64-66 Blinker Switch, Come complete?
Here is a thread I started about finding a part I knew was missing. Has some good column info. http://67-72chevytrucks.com/vboard/s...d.php?t=455929
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-01-2011, 02:41 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
put a pic of what you got, the three items shown will be needed, if your i=using original wheel.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-03-2011, 03:38 AM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: 64-66 Blinker Switch, Come complete?
there not that bad to replace you need a steering wheel puller. a small punch to knock out the doll pin from the column shifter pull the lever out with the spring and the clip. you need a screw driver pillpes 3 long screws you need a 1/4 socket for the shield there just below the column shifter.Lightly pull on both peace.Remember to unplug the connectors under the dash they only go on one way. and pull both peace clear of the column and its self explicitness.the place i like buying it.cus they make the best one so far is at
www.truckandcarshop.com
One other thing you might want to do as well on your steering column is to cut the steering Bar and use the later modal slip joint cus you ever have a front in crash that thing is like a Speer it will KILL YOU.
Now some of the guys i help and they help me they tell me they stated using the 1967--68 steering columns they still use the same emergency Brake handle and the steering column is the same size But comes with the better turn single switch witch you can adapted it into the 1964--66 wire harness.
One last thing or 2 last things Look and see if your lower bearing needs to be replaced #2 your cab mounts you really should change them it will help you re-aline your steering column cus as you have it now if your cab bushing are sagging its putting really bad force on your bottom steering bearing and that's what makes your steering column lose
stsalvage is offline   Reply With Quote
Old 04-03-2011, 03:38 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
I will post pictures tommarow on this topic
Old 04-06-2011, 05:25 AM   #6
RoyL
RoyL's Avatar
Thanks, all. The shop manual seems to be lacking in the details of the blinker switch . . . I have ordered a switch assy from truck shop, will see what it includes. Looks like there's the switch assy, cancel cam and upper bearing that comes with it. Here's what I have now, parts on the floor, nothing yet on the column on the truck, and a pic of the steering wheel I plan to use. I forgot what year it came off of.
1965 Suburban
Old 04-06-2011, 09:32 AM   #7
Clyde65
Clyde65's Avatar
The one I bought from Classic Parts had the turn signal switch and the upper column bearing, but that is it.
http://www.classicparts.com/1964-66-...ctinfo/53-508/
Clyde65
Rebuild of Clyde
support our troops!
Old 04-06-2011, 12:19 PM   #8
RoyL
RoyL's Avatar
Thanks. I may a have a good cancel gadget, so if it's not part of the assy, I can make do.
Roy
1965 Suburban
Old 04-25-2011, 06:34 AM   #9
RoyL
RoyL's Avatar
Roy
Got a switch from Classic. It has the cancel cam and switch. And no screw to hold the blinker stem, re-use the old one. I have a good cancel gadget bolted on the steering wheel that works.
Installed but something's wrong with the horn hook-up, as soon I connect the horn starts blowing, so off chasing something else . . . even with the steering wheel removed, it honks . . .
More on that later
Roy
1965 Suburban
Old 04-25-2011, 08:24 AM   #10
PGSigns
PGSigns's Avatar
You need to seat the bearing in the center of the switch. There is a spring that goes under the wheel to keep the load in this bearing. The spring also pushes the bearing and the brass washer that is on top of it down and away from the horn ring. If you push it down with a screw driver it will clear the horn ring and the problem you have will go away.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-29-2011, 08:14 AM   #11
RoyL
RoyL's Avatar
Jimmy
Jimmy,
Thx, if I understand you correctly, the spring keeps pressure on the steering shaft bearing, holding it in place once the steering wheel is installed? And you are suggesting that the bearing may be in contact with the brass horn contact, causing the horn to blow all the time?
Like I said, I started with nothing installed, and no spring found in all the parts I have. And haven't seen a spring in any shop manual photos, but it does makes sense that the bearing may not be retained without such a spring . . . Got a picture of it?
Duh, I went back re-read your previous post on the spring . . . I see the pic http://www.americanclassic.com/images/HRN-7.jpg
where to find one now?
BTW, I pulled off the blinker switch and I had pinched the black horn wire and that's what was causing the problem. Reassembled, and all is working now. Ya-hoo!
Roy
1965 Suburban
Last edited by RoyL; 04-29-2011 at 03:57 PM. Reason: Duh . . . found the picture . . .
