distributor questions for the pro's
i have a point distributor is there a magnetic pickup i can buy and put in one so i can run an external malrey? sp? box i know i could put a points eliminator in but i would like to run a box. any help would be appreciated
if you have the answer ![]() thanks |
Re: distributor questions for the pro's
TTt
Posted via Mobile Device |
Is this possible?
![]() Join Date: Jan 2001
Pertronix will drop right in.
Bud |
Dave's not here, man
Not 100% but I think you'll need an HEI type distributor to run a standalone ignition box. Someone please correct me if I'm wrong.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
sharp as a marble
![]() Join Date: Jan 2007
I have done a bunch of Pertronix installs. The newest Pertronix do not require you to pull the dizzy. I did one last week in a 57 pontiac. Never pulled the dizzy, took less than an hour. Be sure that you replace the existing coil with an external resistor type coil when you do this. I have had a couple of occasions where the old coil failed shortly after the conversion
Fabricate till you "puke"
I have the "flyin magnet" style pertronix in my 383....slick as he11, & hooked to a big yellow supercoil(Accel). That 383 dont skip a beat, & I have seen her as tight as 7200. All of the pcs are running in an old cast iron dist, that came out of a '62 283, with 150000 miles on it! She does have a nice recurve, & a Crane vac advance tho. Do you really need the big dollar box? I havent seen the need for it
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
