I recently installed a new intake, Holley 600 carb (rebuilt), and valve covers. Everything is installed and still does not work.
Have checked: have fuel coming from carb, have spark plug wires, have hot wire coming from ignition to distributor (HEI), #1 at TDC lines up with #1 plug wire, plug wires are right on dist cap. Any suggestions?? Truck has not run for about 6 month and have spent about 3 days working on it and would love to drive it. |
Designated A-hole!
Have you checked to make sure your getting fire at spark plugs?
You need fuel, spark and timing for your engine to run. It sounds as if you have fuel and your timing is right . Did you check to see if you're getting spark? Also where are you getting power from for your dizzy? Is it coming from a switched terminal on the fuse block? that is, 12 volts with the key "on". Best of luck.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
have u tried to prime the carb to get it started. might need to after it being sitting up
'68 Fleet LWB orig 307 .030 over GM Hei/w Accel Super coil orig. stock TH 400. _______________________ “What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” Albert Pine English author d.1851 |
My other Love
are you 180 degrees out on the distributor perhaps?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Is the HEI functioning and giving good spark..................if its been rebuilt or parts replaced they could be bad...........
Do you get anything out of it when you turn the key?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
