Old 03-23-2003, 02:27 AM   #1
vycc
vycc's Avatar
lifting my 81
i want to lift my 81 GMC SWB 4x4 but i'm very tight on $$$$. i was looking into a 4" lift... i was told to use blocks under the leafs. i've seen this before and i does look nice, i only wish i could get new re-arched leafs, but i can't... so is this a decent way to go. help me out.
vycc is offline   Reply With Quote
Old 03-23-2003, 03:23 AM   #2
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
blocks are ok in the back but not the front. there's too much leverage on the front axle and the blocks can be spit out. try and add a leaf and a small bady lift?
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 03-23-2003, 04:18 AM   #3
Mudder
Mudder's Avatar
Agree! Don't use blocks on the front. 4 inch lifts are very common and you may get lucky and find a used one cheap.
Mudder is offline   Reply With Quote
Old 03-27-2003, 09:28 PM   #4
twistedmetal
Take it to the limit
twistedmetal's Avatar
Take your springs down to a spring re arching shop and tell them you want them to have 4 more inches arch on them,but you must buy the 4" corection steering component or it will be a scary ride,bumpsteer isn't nice.use 3/4 ton springs stay away from blocks if you are gonna be doing big jumps as they tend to bent u bolts and the blocks jump out.Don't forget shocks.Blocks on the front is a no no,unles you are just doing a local mud bog and towing it there and back.
If Fall Guy only knew how many trucks I wrecked,He'd be proud
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
Old 03-27-2003, 09:49 PM   #5
vycc
vycc's Avatar
i am thinking of using 3/4 ton leaf all around as well as shocks... i just want to have enough clearance for my 33's when i go into the bush
1981 GMC Sierra 1/2 Ton SWB 4X4
Old 03-28-2003, 05:18 AM   #6
Ryan Flowers
No Brakes Club
Ryan Flowers's Avatar
Thumbs up
Seen a 4" lift kit with all hardware on ebay for $175............
Like the other gear heads said..... DO NOT USE BLOCKS ON THE FRONT .....................
If $$$$$$ is an issue, I would save until you had enough. Do the job right for your safety.......................& ours!
Put up a wanted post on the parts board..........Someone should be able to come up with something.
Good luck
Ryan Flowers
85 GMC Suburban 4x4 379
90 GMC Suburban 4x4 383
01 Chevy Suburban 2x4 350
Click here to email me
Click here to visit my web site
Ryan Flowers is offline   Reply With Quote
Old 03-28-2003, 06:52 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If your only going to run 33s all you would need is an add-a-leaf in the front (about $60) and one in the back and maybe new u-bolts. That will give you plenty of room for 33s on 8" wide rims and a small 33" on 10" wide rims. The add-a-leafs would give you about 1.5"-2" of lift. This is what I did on an 85 K5 I had with 33s on 15" x 10" rims. When I put the 4" lift on the 33s were too small looking and I ended up getting 35s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-28-2003, 07:09 PM   #8
vycc
vycc's Avatar
that's a good idea, i never thought of that before.. would i need longer shocks?? about how long??
..... do ya think that 3/4 ton leafs or would be too much work.i heard that i'd have to replace the shackles. thanks for all your advise
Old 03-30-2003, 04:47 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I didn't use longer shocks. Most of the shock applications I've seen are listed 0-2" of lift. To put in the add-a-leaf you would not need to take the spring loose from the truck, just remove the u-bolts(support truck at frame) and allow the axle to seperate from the spring pack. remove the spring center bolt(new one w/ add a leaf). Long leaf will go near the main leaf a short leaf will probably go on the bottom. of the pack. Put in new center bolt and reassemble spring u-bolts.
As far as re-arching spring two local shops I called wanted around $350 and all they were going to do is add-a-leaf so it would maintain it's arch. I don't think 3/4 ton springs will get you any higher.
Old 04-03-2003, 02:34 AM   #10
vycc
vycc's Avatar
just so i'm clear... find a set of leafs, take them apart, add 1 leaf spring to my existing leaf pack on my truck, new center bolts and u-bolts... and that should give me enough lift... could i use used leafs ( cheap, cheap ) or do they need to be a certain add-a-leaf.
Jims70GMC you have been a HUGE help, thanks for humoring a 4 whelin' newbie
Old 04-03-2003, 09:30 PM   #11
Big Bad Buddy
hey man i'm no expert bit if it were me i would save the money up until you can do this lift right... add a leaves are a bad idea in these spring packs because of the negative arch in your stock spring and the positive arch in an add a leave. the add a leaf will rub on the stock spring until it finaly breaks through it...trust me it's not pretty. i would save up and buy a two inch lift if that's all you want or go with a 4" a some 35's. i think those trucks should come factory like that anyways! your call but it"s better to do it right the first time and learn from other peoples mistakes. hope this helps.
78 chev pu 12" suspension lift, 3" body. 40" swampers. 85 body. yellow. 69 K5 blazer 6" suspension lift, 3" body. 38" swampers 84 suburban 6" lift 36" swampers... everyone needs a tow rig!!! 70 chev pu with big plans for bags and20's....
Big Bad Buddy is offline   Reply With Quote
Old 04-05-2003, 12:37 AM   #12
vycc
vycc's Avatar
well money is tight and yeah i don't want crap under me, but i have heard people doing the add-a-leaf and it being totally fine... i mean if it would indanger you then they wouldn't sell it. but i appreicate you concern.
Old 04-07-2003, 02:05 PM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I wouldn't use used leafs, it would be hard to gauge the amount of lift get your add a leafs from a manufacture. For ride quality get longer add-a-leafs vice short ones. Some manufacture's have both depending on what you want. I have a short add-a-leaf on the rear of my truck now, it went right above the over load leaf. Should be pic in the link in my signature.
Old 04-08-2003, 07:14 PM   #14
vycc
vycc's Avatar
that makes it a lot clarer.... thanx Jim
