Old 04-02-2011, 09:57 AM   #1
roofingbloke
How Low
Hi All. A quick question for you all.
? how far off the floor will the center of the stock crossmember be with stock controlll arms and bags aired out,
roofingbloke is offline   Reply With Quote
Old 04-02-2011, 10:10 AM   #2
Shane
Shane's Avatar
Re: How Low
... depends on the size of the tire on the vehicle ...
Shane is offline   Reply With Quote
Old 04-02-2011, 10:26 AM   #3
roofingbloke
Re: How Low
18 x 7 with 40 series tyres,
Curently got 15s but scuff line is 2 " lower than rims, (not good)
Old 04-02-2011, 11:59 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How Low
There are so many variables its hard to give you a specific answer. What I can show you is what will happen if there are no fender liners in the way, and you are running a 3" spindle with short cups.
Its hard to tell with the shadows, but the "crossmember" is 3/4"-1" off the ground. The A-arms are resting on the ground hard.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-02-2011, 09:54 PM   #5
broey
Square
broey's Avatar
Re: How Low
that would probably be the lowest you could get with stock control arms and stock crossmemeber right?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-02-2011, 10:10 PM   #6
hotrodhomi
hotrodhomi's Avatar
Re: How Low
unless you bodydrop or Z.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-02-2011, 11:58 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How Low
that would probably be the lowest you could get with stock control arms and stock crossmember right?
Yes, the A-arms are on the ground "hard" at this point. Your not going any lower with out cutting some steel.
Articles-
"Refining Sierra"
Old 04-03-2011, 01:10 AM   #8
broey
Square
broey's Avatar
Re: How Low
yeah thats what it looked.
Old 04-03-2011, 01:12 AM   #9
broey
Square
broey's Avatar
Re: How Low
yeah, I just meant in this exact situation.
Old 04-03-2011, 03:33 AM   #10
roofingbloke
Re: How Low
I have looked into z ing on a small scale. but there seems to be lots of very different opinions,
Old 04-03-2011, 11:21 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How Low
There is nothing wrong with a frame Z IF, and thats a BIG if, it is done correctly. I always hesitate to recommend a Z simply because most of them I have seen done were marginal at best.
Making an angle cut is probably the best starting point. From there, extensive boxing and plating done be a competent welder should be your first priority.
Maybe we can get lakeroadster to do an analysis of the best way to reinforce a Z.
Articles-
"Refining Sierra"
Old 04-03-2011, 02:17 PM   #12
SCOTI
SCOTI's Avatar
Re: How Low
I believe he's 'retired' from structural analysis on the board because of possible litigation concerns should something go wrong.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-04-2011, 02:23 AM   #13
roofingbloke
Re: How Low
I have looked into doing a Z, but what do you do with the front fender/bumper mounting points etc etc,
Old 04-04-2011, 10:06 AM   #14
SCOTI
SCOTI's Avatar
Re: How Low
Basically, they have to be dropped (Z'd) back down what ever amount the suspension pivot points were raised.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
