Addicted to Rust
![]() Join Date: Dec 2009
I think my proportioning valve....
has gone to the bad. When I first got the crew the brake warning light stayed on, so I unplugged it. It had good brakes, so a simple fix. I swapped the rear end for an 88 up 10 bolt to get a better gear for my ls swap. It hasnt really had good brakes since I started driving it again. I had It on the rack yesterday and noticed a fluid leak from the drivers rear wheel. I pulled the drum and the wheel cylinder was leaking. So new shoes and cylinders were in order. I cannot seem to get any pressure to the rear wheels. They will not bleed. I checked the rear line at the hose and I am just getting a dribble of fluid. I checked the master cylinder with a pressure gauge and I am getting 1200 psi with the truck running.
I did not run the master cylinder dry so the pressure differential valve should not have moved and the stem on the front of the valve will not move. Any Ideas where to get a valve for our trucks? It's an 87 2500
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Re: I think my proportioning valve....
Inline Tube & CPP both offer 'new' brass GM style replacement prop valves.
Before you buy one.... what is your process for bleeding? I ask because I've had similar issues on more than 1 truck. It was a frustration to say the least. The cure was I slightly changed by bleeding SOP (procedure).
Addicted to Rust
Start at the right rear wheel and work to the left front. When I get some help here, I am going to bleed from the master to the valve, on both sides of it, then to the rear hose, then both wheels. Its just frustrating, I wanna ride in this thing and it ain't cooperating.
plus since it was rolling I took my bike apart and now have two apart in the shop. Oh well Que sera, sera Jay
When you're bleeding, are you starting w/pressure on the pedal, opening the bleeder valve until the pressure drops, closing the valve, & then removing pressure from the pedal?
#5 | |
Addicted to Rust
I just gotta bleed it from the master out and see where the pressure stops at. I just can't do it alone. Stop by if you get a minute ![]() Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. Last edited by Big Port Jimmy 6; 04-02-2011 at 02:31 PM. |
At the body shop.
you may knocked the safety deal over in the prop valve. my 73 drove me nuts trying to bleed the brakes.. took the prop valve apart manually reset it and gravity bled finnaly got rear brakes
#7 | |
What worked for me (on more than one truck)? I tried bleeding the brakes w/o the initial pedal pressure: 1) Brake pedal is @ rest 2) Open the bleeder valve @ wheel 3) W/the bleeder valve open, press the brake pedal slowly (intentionally slow) 4) Once the pedal is all the way down, close the bleeder & release the brake pedal I tried the 'reset the prop valve' deal mentioned by 'KQQL IT' but was not sucessful. I then tried bleeding using the above method in an attempt @ something slightly different to see if I got different results & it did the trick. My best guess is the pedal pressure was not allowing the pin/plunger to move. It's worth a shot if there's no sure solution.
Addicted to Rust
Bled it at the valve, and then it bled on out and now has good pedal. Musta been some rouge air. Jay
At the body shop.
| Bookmarks |
