Old 04-02-2011, 04:52 PM   #1
jwalk
What was I thinking?
jwalk's Avatar
Valves???
I'm wanting to get everyones input on what your running or have ran in the past. I've been looking at these brands for my next setup... Parker, SMC, GC, ASCO, and DANZ. I've ran danz valves for about five to six months with no problems, but I'm looking for people that have ran these valves for longer time frames. I like the DIN connectors with the DANZ, ASCO, and GC valves. Would all of these brands give me years of service? Just wanting everyones opinion before I order some. I'm looking for good and bad opinions.
Thanks guys!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 04-02-2011, 10:28 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Valves???
I have RideTechs block valve set-up on my blazer.
(The AirPod actually)
My next truck will have Accuair's VU4 valve.
Keith
Convert to disc brakes.
Old 04-02-2011, 10:48 PM   #3
jwalk
jwalk's Avatar
Re: Valves???
Yeah my other truck will have the whole accuair setup also, but on this truck I'm trying to stay more on somewhat of a budget....
Justin
Old 04-02-2011, 10:58 PM   #4
hotrodhomi
hotrodhomi's Avatar
Re: Valves???
I have SMC on my blazer and haven't had any problems with them, 3 years. We run Asco and Parker at work. Different applications, but they are great valve companies. I would put either on on my truck.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-02-2011, 11:22 PM   #5
jwalk
jwalk's Avatar
Re: Valves???
Thanks hotrodhomi! I figured all these valve company's would be fine. I was just wanting to see what most are running.
Justin
Old 04-03-2011, 12:53 AM   #6
nastyc10
nastyc10's Avatar
Re: Valves???
I'm running the GC block valves that kpcomponents sells. no problems after 2 years.
nastyc10 is offline   Reply With Quote
Old 04-03-2011, 12:57 AM   #7
Layedoutsonoma91
Layedoutsonoma91's Avatar
Re: Valves???
I don't care for blocks too much, but I have ran smc valves for 4-5 years with no problem. If you use any valve that isn't a block, I've found it best to make sure you put some kind of back pressure on the dump valve. Like a reducer of some sort. If those type of valves don't have back pressure there is a possibility for them to stick open. And that is funn when your going 60 on the highway. ha
Layedoutsonoma91 is offline   Reply With Quote
Old 04-03-2011, 10:19 AM   #8
Rochlow
Re: Valves???
Air Ride Tech big red valves. I've used SMC valves in the past with no problems too.
Rochlow is offline   Reply With Quote
Old 04-03-2011, 08:06 PM   #9
jwalk
jwalk's Avatar
Re: Valves???
Thanks guys! I'm leaning towards ASCO valves for some reason.
Justin
