Old 04-02-2011, 08:21 PM   #1
JMac11
JMac11's Avatar
Nose High
Put a 4" Rough Country Kit on my Truck, All spring. Initially it was over 2.5 inches high, took out the bottom leaf on both springs still 1.75 high. Truck rides great, am very surprised. Been riding 2 weeks, no settling.
Suggestions? Are the 1.75 Blocks? Really don't want to lower the front.
JMac11 is offline   Reply With Quote
Old 04-03-2011, 12:07 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Nose High
Takes a little longer than a couple of weeks to settle. Even more for rough country springs. I've had mine on for a few years now and I can't say they settled much at all. If you put 4 springs on and they don't match I'd have to wonder if they gave you the correct springs for the rear.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-03-2011, 08:22 AM   #3
Re: Nose High
I don't know what difference 1/4" would make,but you can get 2" blocks.
Old 04-04-2011, 10:01 AM   #4
JMac11
JMac11's Avatar
Re: Nose High
Actually, the rears were right at 4" lift, the fronts were crazy high. Think I will go with 1.5, in case the fronts sag a bit.
Old 04-04-2011, 10:13 AM   #5
onebadbowtie
onebadbowtie's Avatar
Re: Nose High
could always do add a leafs too
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 04-04-2011, 10:22 AM   #6
Burt4x4
Burt4x4's Avatar
Re: Nose High
The mian reason is pre-made springpacks are built based on PickUp weight specs not Blazers so buttsag is common unless you buy custom built packs or mix and match like I did. I ran 5.5"rear & 4" front and my rig sat level with the hard top on. With it off I had a bit of 'stinkbug' but that is better than a saggybutt hahaha
Add a small block too the rear, like ORD 1" ZeroRates
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-04-2011, 01:31 PM   #7
JMac11
JMac11's Avatar
Re: Nose High
Should have Said, this is on my 84 SWB not the K5
