Old 03-23-2003, 11:17 AM   #1
69ChevySB
dropped69
header help
hi i recently got new summit headers for my 69 shortbed. i got the one on the passenger side all bolted down and all, but on the driver side it is much harder. for some reason i can't get the header on right....i can maybe get one bolt in, but then i can see that i probably wont be able to get the others in. and i think it is because its hitting part of the a-arm or its because my flange of the header is hitting the big piece of metal under the tranny that connects the frame....anyone else have this problem with headers? what should i do, all i need is a tiny bit more room, and i can get it on right. thanks.
"And yet I find, yet I find...repeating in my head. If I can't be my own, I feel better dead." -Layne Staley (R.I.P)
69ChevySB is offline   Reply With Quote
Old 03-23-2003, 11:47 AM   #2
theo70
COMING SOON...
theo70's Avatar
Man, I had just the opposite problem with my Hedmans. The driver's side went in no prob, but the passenger side took quite a while. I had to jack up the front end as high as the jack (and the multiple blocks of wood underneath it-not safe) would go and work them in from the under side. I also had to remove items like the starter, spark plugs, etc. If you can't get any help on the message boards, I'm sure there's a tech help line at Summit to help.
That's what we need around here- more Alice fans!
theo70 is offline   Reply With Quote
Old 03-23-2003, 12:09 PM   #3
Low69CST
I put in a set of headmans no problem, i got a smallblock w/auto. Did you put a small block in place of an inline 6?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-23-2003, 12:36 PM   #4
theo70
COMING SOON...
theo70's Avatar
When I bought my 70 last year, it already had a 350 in it, I'm not sure what was in it originally. I then swapped out with a rebuilt 350.
Old 03-23-2003, 12:43 PM   #5
69ChevySB
dropped69
my block is a 327 (or 307?), but my heads are from a 350 i know for sure. anyways, the fit is really really tight with my headers i could actually get all the bolts in, but then i tighten it, it wont go in all the way because the header is hitting the lower a-arm, should i just get a hammer and make a dent where the a-arm touches it, or should i just put another gasket to cover for the extra space, either way seems like it will work, but i don't know just wanted to get another opinion. thanks.
Old 03-23-2003, 12:48 PM   #6
Low69CST
I would try to do a combination. I'd try to trim with a grinder, maybe dent a little with a hammer, only if it was on a spot on the a-arm that was just extra metal. You could also get some thicker gaskets. I have some from Earl's Performance. Didn't have any clearance problems, just got them for extra sealing power. Also, check your Tranny mount. If its crushed then it could be letting your motor sag. Do the same with your motor mounts.
Old 03-23-2003, 12:49 PM   #7
slam33
slam33's Avatar
It's a pain in the A but sometimes you have to go in from the bottom. You need to jack up the front end as high as possible, just support it real good and it will get in there.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 03-23-2003, 12:55 PM   #8
crazy longhorn
Fabricate till you "puke"
if the interferance is with the a arm bushing(top edge,nut side),you could probably grind a little clearance on the nut.....just dont get too wild with the grinder. Good luck,crazyL
crazy longhorn is offline   Reply With Quote
Old 03-23-2003, 12:56 PM   #9
Blue Beard
Blue Beard's Avatar
The engine could be in the wrong holes when put in the truck. May need to be moved back..........
Most of the problems with headers on the right side................
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-23-2003, 07:46 PM   #10
Dreaminator
Dreaminator
I put hedmen elites on my bb and had to grind the frame member on the right side an eighth or so. No problem on the left side. Good luck.
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
Old 03-23-2003, 07:55 PM   #11
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Try installing the driver side from the bottom of the truck.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
