Anyone use brake lines from GMC Paul's?
I bought a new complete set of stainless brake lines from GMC Paul's and I am so confused! A box came to my house, I opened it and it had my brake lines in it. Very nice brake lines too, however, there are no lables identifying which brake line is which. Most are fairly easy to figure out, the 3/16 lines are for the front brakes and the 1/4 lines are for the back brakes. This works fine until you get to the lines that cross the rearend, there is not enough 1/4 line to plumb the rearend and too much 3/16. Do the lines change size at the rearend from 1/4 running from the master cylinder back to the rearend and change to 3/16 as they cross the rearend from left to right. That said, I think there more brake lines supplied then are required, just not the correct sizes and lenght. HELP!
![]() Join Date: Feb 2001
Re: Anyone use brake lines from GMC Paul's?
I would send Paul an email asking for help and he would likely send a diagram. Be patient and I am sure you'll get some help from here also.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Do you have the old break lines? i know its a stupid question
1969 Chevy c20(Miss Hackjob) |
They do switch sizes at the rear end. The switch occurs at the junction box on the rear flex hose.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Is pals a good place to order from?
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
