Old 04-03-2011, 07:31 PM   #1
GMCshorty
Headers for big block 4 spd
Hey everyone. I was wondering which headers to use in my 71 2wd. Its a tall deck big block with a super T-10 behind it. Is there any that wont have problems with the clutch linkage and stuff? Thank you.
GMCshorty is offline   Reply With Quote
Old 04-04-2011, 12:48 AM   #2
ItsRandy
ItsRandy's Avatar
Re: Headers for big block 4 spd
I just bought a set of Hookers for my big block 69. Clutch linkage problems were the least of my problems. Interfearance between the head bolts and the header flange and interfearance between the driver's side lower control arm proved to be bigger problems, once those two problems were solved the headers fit/look great.
ItsRandy is offline   Reply With Quote
Old 04-04-2011, 10:51 PM   #3
Pondscum
which set of hooker headers did you get?
was wonderin because tryin to get all my parts together for when I convert my 67 C10from 250 i6 and 3 on the tree to a 454 and m20 muncie. While doing this I'm converting to disc brakes by doing a crossmember swap from a 78 burban that the bbc coming from.
Any help would be helpfull
Pondscum is offline   Reply With Quote
Old 04-05-2011, 12:40 AM   #4
ItsRandy
ItsRandy's Avatar
Hooker part number 2841-1. Don't forget to get the correct big block motor mount stands. When Hooker (and most other header mfgrs.) build a set of headers they build them on a completely stock truck, stock iron heads, mounts etc. I had to have full length headers. The shorty or 3/4 length headers may be easier to install, however, the primary tube lengths become unequal which don't make as much horsepower as equal length full length headers.
Old 04-05-2011, 12:56 AM   #5
ItsRandy
ItsRandy's Avatar
Here are some pictures.
Old 04-05-2011, 09:11 AM   #6
GMCshorty
How far down do they hang below the frame? Would you have a pic from the side so we could see? Thanks
Old 04-05-2011, 11:41 PM   #7
ItsRandy
ItsRandy's Avatar
Yes I have a picture. They hang pretty low. They have 3 1/2 inch collectors. The only headers I found, that were full length, that tucked up tighter were Doug's...they have been discontinued.
