04-03-2011, 08:18 PM | #1 |
bottom ball joints, HELP
Hi All, I'm in the process of replacing my ball joints in my 69 C/10. I have all my parts, Have everything loose. I know that I have to get rid of the rivets in the top.... how do I get the bottom ball joint out. I'm hoping I can do it without having to take the thing somewhere to have it pressed out, then have the new one pressed back in... It looks like thats what I'm going to have to do. UNLESS,,, someone can HELP me Please
Pete The worst I ever had was wonderful 69 SWB work in progress 97 Ranger 6in. lift on 35's 04 325i lady's ride |
04-03-2011, 08:34 PM | #2 |
Formerly- 1972SuperCheyenne
Re: bottom ball joints, HELP
You can knock it out the bottom of the control arm with a hammer. Might be a little tough but they will give up once you smack them a few times!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
04-03-2011, 08:48 PM | #3 |
Thanks a million, figured I had ran into a wall. Never hurts to ask...Thanks
04-03-2011, 08:58 PM | #4 |
your best bet is using a ball joint press. there are some parts stores that loan them out.
04-03-2011, 09:59 PM | #5 |
well i have found to get them out so u can clean the arms up before you have the others pressed in just lay the arm on something solid with the bottom of the ball joint hanging over the edge i found a curb works great lol but smack the top of the joint with a sledge hammer and it should pop free but you do have to have the new ones pressed back in
04-03-2011, 10:08 PM | #6 |
Guess I better call some parts stores first thing in the morning. I was hoping I could just knock them out and get it started back and pull it up with a inpact wrench. Didn't want to remove the a-arm.. Thanks for the info
04-03-2011, 10:15 PM | #7 |
Cruzin
you can do it with them in the truck with a big hammer, place a jack or something under the a-arm with ball joint end open and whack it. As for the new ones whack them in also. The last ones i did i left the spring in and shock attached with a jack under the a-arm/and i have removed the lower arm too before but still always used a big hammer.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
04-04-2011, 06:38 AM | #8 |
I'll give it a try. Don't have a very big hammer, got a good swing though
04-04-2011, 08:04 AM | #9 |
Jess I don't if this will help or not. I just replaced my upper and lower ball
joints in my 68, I drove the lowers out with a hammer and to put them back in I set them in the Freezer overnight and then set them in place and tap them back in. Of course the proper way is to have them pressed in but I don't think the way I did it hurt anything. |
04-04-2011, 08:12 AM | #10 |
The ball joint press that I have is portable and you do not have to remove the a-arm to use it. You should try to find a loan or rental program somewhere that has one. Jim
04-04-2011, 08:22 AM | #11 | |
04-04-2011, 10:09 AM | #12 |
I used BFH and after about a few hits they popped out really nicely. putting the new ones in I put some bearing grease around the edge and held it in place and tapped it with the BFH and it went right in.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
04-04-2011, 10:31 AM | #13 |
FYI, if you find my thread on this exact subject I spent a whole day trying to dissamble just the passenger side and a about an hour trying to get the upper driver out, to no avail.
I was using a standard claw hammer and it was just beating up the studs. I then went and replaced my newly lost 4# mini sledge, literally two wacks and both upper and lowers popped out. (This after having spent an hour just trying to get the upper out to see it not move a cm. Moral of the story: The hammer needs some weight on it.
www.tomthetruck.blogspot.com <-- Aka build thread. |
04-04-2011, 10:34 AM | #14 |
Well, used the BFH method. worked rather well. However I did soak it down with WD-40 and left it overnight. Put the new one in, put a bottle jack under it, put pressure on it, used the BFH and tapped alittle on the a-arm, went right back in place. Grinded off the rivets on the top, banged on it, got it out. Bolted the other one in and S%@T... Wrong ones. So I'm off to the parts store.. Dang I hate to order a part, happens everytime I try to shave a couple dollars off.. Should have went to NAPA to start with, could have had it done a week ago, Instead of waiting on the mail.. Oh Well.. Thanks for all the advice, Wouldn't have even started it without you guys..
04-04-2011, 10:41 AM | #15 |
i did mine with the LCAs in the truck with a ball joingt dress from AZ took me about 30 mins for both sides
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
04-04-2011, 06:07 PM | #16 |
Junior Member
Harbor Freight sells a press that can be used for lower ball joints and u-joints. I bought one a couple of years ago and it works ok.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-04-2011, 06:59 PM | #17 |
Finially got it finished. Bigger job than I thought. I'm not exactly sure I put the right ones back in it though. The new ones wasn't as long as the old ones. the old ones had more threads on them. I went to 3 different places, none of them would go through the spindle far enough to get a full nut on the ball joint. tightened one up so tight it stripped the threads. I don't know run it and retighten them I guess...
04-05-2011, 03:27 AM | #18 | |
04-05-2011, 07:05 AM | #19 |
They fit and match up perfect. There just not as long as the old ones. There's more threads on the old ones. I can't get enough nut on it to get the cotter pin through...Don't know why there so short, I checked different places. All were the same length, I don't know what the problem is
