04-03-2011, 09:24 PM | #1 |
Saginaw four speed
Can you put one of these in a 67 c10 with a 327. The four speed muncie
that is in there is a 3 speed as the granny gear is useless on the street... The saginaw came out of a 66 el camino with a big block, so it should hold up to a 327. I think there is shifter linkage available as well...what do ya think folks, has anyone done this before?
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
04-03-2011, 10:22 PM | #2 |
Registered Cruiser
Re: Saginaw four speed
It's an easy swap. You should even be able to use the same driveline. The Saginaw isn't the strongest 4-speed out there, but they're fine in our trucks. I like them. They're very fun to drive, smooth running, and quiet in proper condition. If they break, replacement parts are easy to find, and affordable. The Hurst linkage kit puts the shifter far enough forward that you could have a bench seat if wanted. The bummer is that the shifters are expensive, and unless you find a good deal on a used one prepare to spend more for it then your tranny.
I intend to live forever. So far, so good. |
04-03-2011, 10:41 PM | #3 |
John,
The one you have there has 3 Rings on the imput shaft which should mean a 3.50 1st. Is yours a Vega/Monza type? I came close to buying one just last week, but the levers and rods were missing on the Hurst Shifter. I called Hurst and they told me that those rods are different on the Vega/Monza type and that they don't make them anymore. A 3.50 first would be nice in my '72 C-10. I've got a 3-Speed in it now. Bill |
04-03-2011, 11:32 PM | #4 |
Registered Cruiser
@Bill; AFAIK the linkage rods were all the same. I think maybe the vega/monza trans had a weird mount that interfered. I like the 3.50 low gear much better than what was in the other saginaw I had. The one in the picture is a transmission that I bought just last year. It came with the new shifter and linkage, which was great because after twelve years my old shifter was almost shot. I had freshened the old transmission up a couple times with new bearings, synchros, etc, but it was so worn it wasn't worth rebuilding again. I didn't realize just how bad it had gotten until I put the fresh gearbox in. I might sell my old spare shifter/linkage. The shifter is tired, but you can't really wear out the linkage kit. If I do I'll put it on the parts board to keep it fair to all involved. I hadn't really thought of selling it.
04-03-2011, 11:53 PM | #5 |
JHW- Cool pic however the trans I just got has 5 mount bolts or a triangle
piece of casting front center top. It does not have grooves in the shaft. Casting mold number is M21 with the big GM letters. Will get some pics in the AM. I hope it is what the guy at the swap meet said it was....lol I checked the net for shifters and you are correct about price....
04-04-2011, 12:00 AM | #6 | |
Brett |
04-04-2011, 03:47 AM | #7 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-04-2011, 04:22 AM | #8 |
KEEP ON TRUCKIN'
My Dad has a Sag in his '67 hooked up to a 283 so it will work in your truck. Just make sure you get the install kit for a Saginaw.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
04-04-2011, 06:56 AM | #9 |
I have friends who have always run 4spds. The Muncies cost so darn much that they grab up Saginaws. Between the Saginaws and Borg Warners they have had better luck with Saginaw. One has a Saginaw behind a ZZ4 and it's doing fine. I won't say he's bangin' gears like there's no tomorrow,but it's getting full torque cuz Eddies enjoys that motor
04-05-2011, 04:30 PM | #10 |
Registered Cruiser
For anyone interested I listed a shifter and linkage kit for a saginaw on the parts board.
I intend to live forever. So far, so good. Last edited by jhwkns; 04-05-2011 at 04:30 PM. |
04-09-2011, 05:36 PM | #11 |
I installed a saginaw 4 speed out of a Vega in my 69 short stepside,running a 350 engine. I used the vega shifter(it bolts to the floor,not the trans.) Ithink I cut the stick and angled it forward for seat clearance.I used this truck as a daily driver for several years,and had no problems.
08-18-2011, 10:15 PM | #12 | |
64 chevy c10 swb fleet small back window , in progress 454/400 swap , disc front disc rear , and just geting it on the road . 09 ford f350 cc swb 4x4 6.4l , to haul the others home . 2011 chevy hhr not mine but love the milage .. |
08-19-2011, 12:49 AM | #13 |
I bought the cheapy Hurst shifter, I believe they call it an Indy. It was a piece of junk. I sent it back.
08-19-2011, 10:08 AM | #14 |
How much more top end does the Saginaw 4 speed have over the saginaw 3 speed?
08-19-2011, 12:33 PM | #15 |
None. The high gear in each would be 1:1.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-19-2011, 01:19 PM | #16 |
Guy i work with had a 69 3/4 2wd with a 396 in it, he put a saginaw 4 speed in it, used the 3 on the tree shifter, for it, had all 4 gears, and had a shift rod up through the floor for reverse. Said it worked good, unless you left it in gear on the column and pulled the lever for reverse, it was a ***** to get unstuck when he did. lol
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
08-19-2011, 09:53 PM | #17 | |
Registered Cruiser
Yeah those are pretty poor. They don't compare at all to the comp plus shifters.
