Old 04-03-2011, 09:45 PM   #1
lil hoodlum
lil hoodlum's Avatar
new drop shocks
Hello everyone. I installed some new "drop shocks".
I've installed some Monroes #5752.
Specs: 8.625" compressed
12.75" extended
My front is lowered with drop springs, aftermarket stock height spindles with disk brakes. I have been trying various "drop shocks" and not having much luck with them lasting more than 6 months or so. I've the dropshocks from Mcgauphys, LMC, and some Monroes 33033. The Monroes 33033 I believe are for the 88-98 chevy trucks.
Anyways how about some pics?
lil hoodlum is offline   Reply With Quote
Old 04-03-2011, 09:50 PM   #2
lil hoodlum
Re: new drop shocks
Drivers side. My suspension keeps bottoming out on dips and bumps. Note wasted bump stop.
Well we will see how long these shocks last. The "old" monroes 33033 only lasted about 6 months. My truck is a daily driver if that makes a difference.
Keith
Old 04-03-2011, 11:17 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: new drop shocks
what did these run apiece at the store? cool for sharing !
John
1999 Toyota Tacoma 4x4
Old 04-04-2011, 12:26 AM   #4
1971_402
1971_402's Avatar
Re: new drop shocks
what is your drop !
1971_402 is offline   Reply With Quote
Old 04-06-2011, 11:56 PM   #5
JON70CST
JON70CST's Avatar
Re: new drop shocks
Originally Posted by 1971_402 View Post
what is your drop !
Ditto ^ ... I'm dropping 3" in the front and 4" in the rear :s hopefully it sits level... but anyways, I will also be needing drop shocks and wondering which I should go with.
JON70CST is offline   Reply With Quote
Old 04-07-2011, 01:14 AM   #6
lil hoodlum
Re: new drop shocks
my drop is only 2" in the front. Rear is stock height.
I think the shocks were $22.00 at O'reilys.
Keith
Old 04-07-2011, 01:56 AM   #7
Rooster's 67
Rooster's 67's Avatar
Re: new drop shocks
uh replace the bump stop, the shock bottoming out will destroy them. that stop aint doin nothing
Rooster's 67 is offline   Reply With Quote
Old 04-14-2011, 02:53 PM   #8
72gmcshorty
72gmcshorty's Avatar
Re: new drop shocks
if you were bottoming out with the old length shock, why would you go with a shorter shock?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-14-2011, 03:15 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
Re: new drop shocks
Looks lower than 2" drop in the front. Looks more like 4". Might help if the rear was lowered a couple inches to...will actually bring the front up a bit....
I do like a rake to the truck but that much rake is probably causing your bottoming out issues...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-31-2011, 03:38 PM   #10
PLANETGETLOW
Re: new drop shocks
I'll be trying these out as well
PLANETGETLOW is offline   Reply With Quote
