Old 04-03-2011, 09:56 PM   #1
gavinmosher
Need help guys... Sorry I keep asking!
Okay guys my 84 with a 454 out of an RV was running well before i did the intake and carb swap,
It will now fire up but will not stay at an idle without me pressing the gas pretty hard,
I thought it was a vaccume leak so i bought new gaskets again and reinstalled the intake with new gaskets and cleaned it even better than before and reassembled
i even pulled the valve cover to make sure when i had it on what i believed to be "TDC" so i could make sure both valves were closed when the number one cylinder came to the top
NOW after all the reinstallation I tried firing her up and she started after pumping the gas, but as soon as i let off kaput she died again.
I stuck a timing light on it and it seemed way off time it was a good 2 inches to the left of the timing mark and got further away from the timing mark as I gave it some throttle
Can ANYONE give me any advice as to what i am doing wrong here?
gavinmosher is offline   Reply With Quote
Old 04-03-2011, 11:43 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Need help guys... Sorry I keep asking!
Did you put a big ass carb on it?
lilpoindexter is offline   Reply With Quote
Old 04-03-2011, 11:54 PM   #3
gavinmosher
It's an edlebrock not sure of the size but it did the same with my 600 Holley
Old 04-04-2011, 01:19 AM   #4
travo77
travo77's Avatar
is the carb new or used
travo77 is offline   Reply With Quote
Old 04-04-2011, 01:21 AM   #5
gavinmosher
They are both used but the Holley came off my 84 crew cab chevy with a sbc In it. Also I was thinking if my timing mark is off to the left then my timing is wayy behind I need to advance it to make it come to the right of my timing mark to show advanced correct?
Old 04-04-2011, 08:51 AM   #6
justinburnett
justinburnett's Avatar
if it's getting farther off wouldn't it be too far advanced? because the vacuum advance would put it farther advanced, otherwise if it was retarded it would get closer to tdc when you gave it gas. At least that's how it's working in my head.
justinburnett is offline   Reply With Quote
Old 04-04-2011, 09:44 AM   #7
wyattglock
wyattglock's Avatar
I agree with Justin on this. It sounds like you have it to far advanced. Without standing there and looking at it, it sounds to me like you are one tooth off on the distributor. If you cant turn the distributor counter-clockwise and get it on 0 degrees with your timing tab. You will have to pick up the distributor and reinstall it one tooth retarded from where you are at.
BTW, don't apologize for asking. Smart people know when they need help!
wyattglock is offline   Reply With Quote
Old 04-04-2011, 11:12 AM   #8
gavinmosher
I knOw it sounds weird but with the timing light hooked on to it it started off around 16 degrees retarted and honestly as I brought The rpms up it moved further left toward the water pump
Old 04-04-2011, 11:38 AM   #9
gavinmosher
SomeOne on another site said something about an est wire causing issues what the heck is an est wire for one thing and Also there is a tan wire on my harness right behind the distributor that was cut and not wired into anuthing I'll try to upload a pic
Old 04-04-2011, 11:40 AM   #10
gavinmosher
Old 04-04-2011, 12:48 PM   #11
gavinmosher
The more I think abou it If the timing mark is moving further left then yes it is advancing because it is moving toward the advanced side of the balancer
Old 04-04-2011, 01:04 PM   #12
pig rig
pig rig's Avatar
with out being there and looking at it or hearing it and going buy what you've said in both threads on this I'm going to say it's NOT the carb its in the timing
so its ether not advancing or the modual is working right or your dist is not in right
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 04-04-2011, 01:52 PM   #13
gavinmosher
Okay I got the bright idea to try Closing the CHOKE to see if it would run, i closed it off and it stayed running but as soon as i opened the carb it died instantly this tells me its a vaccum leak, Does anyone know how to go about troubleshooting a vaccum leak??
Old 04-04-2011, 03:00 PM   #14
manimal
manimal's Avatar
starting fluid. Spray around the gasket area and the carb. If the idle changes,you've found the area leaking.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
