Strange trans hump?
I found this trans hump for sale and it has me confused. I know that the 4x4s and the 4 speeds had the removable humps, but why would a 2 wheel drive automatic?
http://milwaukee.craigslist.org/pts/2303215136.html
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
its all about the +6 inches
Re: Strange trans hump?
all big blocks with automatic got the high hump.
a big block 2wd truck has a hump in it
These were put in to clear the TH400 tranny's behind the BB
I had a 70 with a 350/TH400 had the same hump in it. |
AH, didn't know that, thanks guys!
Dont all trucks have a removable hump? I have a 69 C10 w/auto and a 72 GMC 4X4 w/auto, both of them have removable trans hump. I also had a 70 GMC and a 71 Chevy, 1 manual the other auto and they had the removable trans hump. The autos except my 4X4 all had the small hump but they all come out by removing a few bolts. I thought they all did?
Posted via Mobile Device |
^^^^I think the lower humps didnt bolt out. If im wrong im sure somebody will correct me.
1969 Chevy c20(Miss Hackjob) |
Roadtrip!
![]() Join Date: Feb 2003
The low humps are part of the cab and not removeable. A Big block/th400, 4 speed truck, or 4x4 generally had the bolt in hump.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
so a th400 doesn't fit a low hump
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#11 | |
Roadtrip!
Never made a bolt in low hump that i have seen. Your 69 probably had a TH400 behind it originally.
#13 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
No, there are NO removable low hump trans tunnels from the factory in any 67-72.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#14 |
I replaced the original TH350 in my 69 a few years ago and installed a four speed out of another truck I bought, my grandfather bought my truck new. Anyway, when I replaced the trans I had to simply unbolt my small hump and bolted in the tall hump out of the donor truck. I had the same removable low hump in my 71 C10, I unbolted it when I replaced the trans in it. I'm confused now.
#15 |
Roadtrip!
If they were bolted in, they were hi-humps.
#16 |
I must have some unusual trucks then, when I pulled the TH350 in my 69, I had to unbolt the low hump because the four speed wouldn't with it, I had bought another truck so I could use all the parts like the clutch linkage, pedal, drive line and the taller hump. When I was done I remember bolting the low hump in the donor truck when I sold it. Either way, I guess I had a couple of oddball trucks because they definitely had removeable low humps.
Maybe someone put in aftermarket low trans humps in two of my trucks, I don't know, but I do know they were there. I must have been lucky! Thanks. Posted via Mobile Device |
#17 |
What some people do if they need the extra clearance is cut out the small hump and bolt a high hump in.
You're not old, it IS loud! 1970 CST-10 BB 400 ![]() |
#18 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
A turbo 400 fits under a low hump cab. It's just closer to the floor than a high hump cab will be. If you have nice cab mount bushings it will clear fine. Only if you try getting by with 40 year old saggy original mount bushings do you have interference issues.
#19 |
Just as a side note, there are odd ball trucks out there - mine was a 307, 3 on the tree, 2 WD LWB and I have a bolt in high hump cab.
#20 |
A th400 will bolt into a small hump truck with no mods, i did it with a big block and a 400th in my 69 short step.
#21 | |
#22 |
the TH400 didn't dictate a high hump, that one always comes up and i always wonder where that info comes from. A th400 with a big block got the high hump, but a th400 on a small block or inline got the low hump
#23 |
I had a C/30 350/TH400 with a low hump floor. I never saw any low hump that bolted from the factory. It would have been a great idea,if they did.
BTW,that automatic 2wd hump is a great deal.Did you snag it?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-05-2011 at 08:14 AM. |
#24 |
No, didn't get it. I have quite a few already, but had never seen one without holes in it.
#25 |
![]() Join Date: May 2001
x2......
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
