04-03-2011, 10:27 PM | #1 |
1/2 ton to 3/4 ton axle swap
Im looking for some information on swaping my 72 axles out for a corporate 14 bolt rear and possibly dana 60 front.
04-04-2011, 08:36 AM | #2 |
Re: 1/2 ton to 3/4 ton axle swap
If they are the same series (years) it should be pretty easy. You may need different U-joints and you will need to check the drive shaft lengths and may need a brake job. There is a TON of info on the web about that swap. Should be pretty easy.
04-05-2011, 10:04 AM | #3 |
The front will bolt in. The rear spring pads and shock mounts are in different locations. No biggie,just has to be addressed.
04-05-2011, 11:12 AM | #4 | |
Hope this helps, Joe |
