Old 04-03-2011, 10:30 PM   #1
stich626
long arm bushings..
I'm in the middle of adding lowering blocks (2")
and well it's only one more bolt and the e brack cable and the arm is off. my bushings look like 40+ y/o worn out bushings..
ordered energy bushings , they come without the outer metal sleave.
now poly has a rep. of squeaking, should I add a zerk fitting to the outer sleave? so they can be greased every now and then
stich626 is offline   Reply With Quote
Old 04-03-2011, 11:01 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: long arm buchings..
I got poly bushings, they stopped sqeaking after a few thousand miles..?
A grease fitting would probably be a good idea
John
1999 Toyota Tacoma 4x4
Old 04-04-2011, 12:40 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Use the silicone grease recommended by ES, slather them in the stuff, and never, ever, ever, use the red bushings. Regular petroleum based grease will last a week or two, the stuff they recommend is like glue, only it doesn't clean up as easily
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-04-2011, 06:34 PM   #4
oldblue1968chevy
+2 for being the consistancy of glue, i was like crap how does this lube ANYTHING lol
John
