Old 04-04-2011, 09:17 AM   #1
PLANETGETLOW
1972 C-10 - Interior Kick Panels
I'm lookin for a set of kick panels that I could use to put a set of speakers in, anybody have or know where I can get these?
PLANETGETLOW is offline   Reply With Quote
Old 04-04-2011, 09:24 AM   #2
6772owner
Gearhead
6772owner's Avatar
Re: 1972 C-10 - Interior Kick Panels
I am pretty sure that LMC sells them, you might also check the vendors on the board, they can usually get just about anything and are great to deal with. Someone else should chime in as well, but a lot of guys also make there own out of wood/fiberglass.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-04-2011, 09:50 AM   #3
stich626
I used a set from custom autosound,
be prepaired to bend the e brake pedal , i heated mine and bent it (take the rubber foot pad off first)
had to adjust the pass side vent vac can.
other than that piece of cake..
my speakers where a little to deep and hold the center out some (can't tell)
stich626 is offline   Reply With Quote
Old 04-04-2011, 09:53 AM   #4
stich626
Old 04-04-2011, 09:57 AM   #5
Jeffs70
Jeffs70's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=377983
Jeffs70 is offline   Reply With Quote
Old 04-04-2011, 10:17 AM   #6
stich626
nice
Old 04-04-2011, 10:25 AM   #7
PLANETGETLOW
Originally Posted by stich626 View Post
Yea, like those!!
Originally Posted by Jeffs70 View Post
Very nice, pricing is right too
Old 04-04-2011, 10:47 AM   #8
PLANETGETLOW
When you put the speakers in the door like that, where/how are you runnin the wires?
Old 04-04-2011, 01:20 PM   #9
big_al_71
big_al_71's Avatar
I have a set in my truck they sound ok at best but they do the trick it is not like if I could hear it thru the sound of the motor...
I think mine are from LMC
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-04-2011, 01:37 PM   #10
stich626
there is a 1/4" hole in the door at the hinge near the light swtch
and a matching one on the cab pillar
I ran mine from the speaker to the oval hole at botton of door trim(behind it) and then to hole near front of door then to hole in the hinge area, I try'd going straight up the inner door but the inner brace is in your way, it can be done but its a pita, and the holes for the way I ran it are already there..
used a piece of coathanger to fish it through the door and pillar
Old 04-04-2011, 01:43 PM   #11
custom1970
Member
custom1970's Avatar
I have similiar ones, they can also be painted to match your interior. Mine sound ok, they came with low qualitly speakers in them, but i've since replaced them with a set of pioneer speakers. Also had to do some cutting to make them fit, but not a big deal to do.
custom1970 is offline   Reply With Quote
Old 04-04-2011, 01:46 PM   #12
stich626
looking at this paint pad fail of a door
if you look at the two dots and the line between them.. this is where I ran the wire to get passed the inner brace. then into the hole on the door and then the pillar
hope this helps
note these holes are behind the door trim.. you'll have to remove the window crank,arm rest and trim panel
Old 04-04-2011, 02:06 PM   #13
PLANETGETLOW
hope this helps
I mean from the door to the cab.
Old 04-04-2011, 02:13 PM   #14
stich626
mine had holes under the upper hinge a little above the interior light switch in the pillar and the hole in the door lined up.. no idea if it was there stock or added sometime in the 40+ years on the road.
Old 04-04-2011, 02:14 PM   #15
stich626
i'll take pic's later it's pouring here now..
and post them.. on the door to pillar
Old 04-04-2011, 02:16 PM   #16
PLANETGETLOW
thanks and yes........
Old 04-05-2011, 12:33 PM   #17
stich626
didn't forget still raining hard,,
