Closed Thread
Old 04-04-2011, 11:12 AM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Engine & Drivetrain FAQ index.
This thread will be used as a FAQ index for the Engine & Drivetrain section. You will notice some of the old stickies in this section went away. Don't worry no info was lost, just re-organized here. Once the Main board FAQ is finished and all of these FAQ's are moved there, this thread will just be a link to there and also act as a place for working FAQs.
If you have a thread you would like added to the Engine and Drivetrain FAQ or have any ideas, please feel free to send me or another Mod a PM.
FAQ:
SBC Ignition timing
Online engine resources (casting numbers, calculators, etc.)
Opinion on how to start motor after it has sit for almost 2 years
Flat-Tappet Cam-compatible Oils
How to install a Camaro T-5
700r4 speedometer calibration
60-62 Big 6 to SBC motor and trans mounts
283 valve covers on a 350
Serp setups
TH350C: How to set up the lockup
700R4 Speedo calibration
York AC compressors: Recondition & rebuild
Alternator bearing how to
2nd Gen V8 frame plate dimensions
V belt pulley alignment 101
203 part time conversion Nash shaft instructions
Driveline angle FAQ
Chevy Six Cylinder Casting Numbers
T-56 Rebuild with Mid-Shift Conversion
12 bolt rebuild + Eaton Posi
If submitting a topic for FAQ, please use the site Gallery to host your pics!!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline
Closed Thread
