04-04-2011, 11:15 AM | #1 |
3 Speed on the column wiring Harness?
I am looking for a underdash wiring harness for my 68 . Two questions. I am going to put an automatic trans in the truck and want an undersash harness for an automatic which has the reverse light and neutral safety switch at the fuse block.
Will the 69-72 fuse blocks bolt right up ? I noticed the fuse block on the 68 is turned sideways compared to the later models. Two will a three speed on the column harness have the correct wiring to adapt the automatic at the fuse block? |
04-05-2011, 10:27 PM | #2 |
Restoration Virgin!
Re: 3 Speed on the column wiring Harness?
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-06-2011, 01:50 AM | #3 |
Msgt USAF Ret
I'm not sure if I understand you but the neutral safety switch is mounted on the steering column not down by the fuse block. If you don't have an automatic column you will have to get one, or adapt the std column.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
