Old 04-04-2011, 11:53 AM   #1
blackbeaSSt
cab trim removal
how do the 2 side pieces and back come off? i messed around with it but i didn't wanna pull too hard and break something off
blackbeaSSt is offline   Reply With Quote
Old 04-04-2011, 11:57 AM   #2
Jonboy
Slots go on anything!
Re: cab trim removal
The end caps are bolted on, and the center section is held on with clips. Reach up into the cab pillar to access the bolts, and then work the center up and down to get it loose from the clips.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-04-2011, 12:58 PM   #3
blackbeaSSt
roger that! even my duh huh self can't mess that up
Old 04-04-2011, 02:16 PM   #4
Pop's C-10
Pop's C-10's Avatar
This should be in tha FAQ's
Pop's C-10 is offline   Reply With Quote
Old 04-04-2011, 02:37 PM   #5
blackbeaSSt
there's a faq forum
Old 04-05-2011, 06:59 AM   #6
Pop's C-10
Pop's C-10's Avatar
I may have worded that wrong, but i know this is something that asked alot..i wonderd myself till i seen a post on it. That save me from taking flat head to tha end caps to try& get them off..lol
Old 04-05-2011, 08:54 AM   #7
babyJay
Arrived on a Pale Horse
babyJay's Avatar
been there and done that. they don't add much to a load of scrap either.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-05-2011, 01:22 PM   #8
BigMike608
BigMike608's Avatar
If I remember correctly it is a 10mm
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 04-05-2011, 01:37 PM   #9
blackbeaSSt
thats even better! glad i got skinny hands to get up in there!
Old 04-05-2011, 02:03 PM   #10
RandyP
Getting Old; Going Broke
RandyP's Avatar
A cordless ratchet is your friend when doing the cab corner moldings.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-05-2011, 02:09 PM   #11
blackbeaSSt
ugh. don't have one of those! im sure i'll have some busted knuckles when all is said and done
Old 04-05-2011, 07:51 PM   #12
blackbeaSSt
well that wasn't too bad. the brackets were almost rusted to pieces but they will hold! the previous owner also didn't have nuts on there but rather a small bowl shaped thingy?! so i had to round up 2 .06 nuts at ace hardware!
all in all not too bad but it doesn't seem to fit as flush as the others though. oh well
Old 04-05-2011, 09:22 PM   #13
Pop's C-10
Pop's C-10's Avatar
bowl shaped things are tha nuts i beleave,,,most cars had them..
Old 04-05-2011, 09:42 PM   #14
RandyP
RandyP's Avatar
Should be thread cutting nuts on there.
Old 04-05-2011, 10:23 PM   #15
blackbeaSSt
yup thats them. thats all that was on there. and of course i dropped one down somewhere so i said screw it and went and bought 2 nuts!
