Info. On a 12 bolt
looking to buy a 12 bolt from a 71 or 72, but how can I I.D. the rearend to make sure I don't buy the wrong rearend?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Info. On a 12 bolt
5 lug axles of course, plus the canted axle saddles for trailing arm and also the panhard bar spud.
If you see those three items, you've found your 71-72 rearend.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-04-2011 at 03:33 PM. |
Restoration Virgin!
I have a rear axle out of a 71 truck....look for casing numbers on the gear housing....mine has NF 3896838 near the fill plug.....also if you cannot get the gear cover off, look on top of the passenger axle tube should be a code there to tell ya what gear ratio and if it's a posi along with other data....or spin the wheel and count the revolution the driveshaft makes makes....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
i'd want the rear cover removed to see the condition and check the ratiio of 40 year old gears before i'd buy
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-04-2011 at 04:16 PM. |
and if you open it up, have rubber gloves and hold ur nose
Ok I have another question. I've read that the 71-72 rearends are wider then the 67-70 rearends. How much wider are they? Will It be a problem later if I want to put rims on it?
Restoration Virgin!
1.5" total....3/4" each side....it all depends on what wheel you want to run
#8 | ||
If you put a 67-70 truck next to a 71-72 truck you'd be able to notice the wider stance by comparing the two but lacking the direct comparison, it's not noticeable. A set of 8 inch truck rallys fit perfectly. I think the narrower 67-70 truck stance looks a little too narrow myself and 71-72 look ideal.
![]() Join Date: Nov 2006
X 2 FOR ME HERE...
The 1.5 inches is nothing to get wrapped up in. Think of it this way, your truck will be the stock 71-72 truck width. If you put a 67-70 truck next to a 71-72 truck you'd be able to notice the wider stance by comparing the two but lacking the direct comparison, it's not noticeable. A set of 8 inch truck rallys fit perfectly. I think the narrower 67-70 truck stance looks a little too narrow myself and 71-72 look ideal.
I BELIEVE IN JOHN 3:16 |
