Old 04-04-2011, 02:39 PM   #1
Andyboy
Andyboy's Avatar
Used a/c compressor
Found a used a/c compressor, but can you rebuild the used ones or is it better to buy a new one? also its out of a 72 and mine is a 68, will it work? thanks
Andyboy is offline   Reply With Quote
Old 04-04-2011, 04:15 PM   #2
MARKDTN
Re: Used a/c compressor
Buy a new one. No question in my mind.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-04-2011, 06:15 PM   #3
leddzepp
Moderator
leddzepp's Avatar
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 04-04-2011, 07:05 PM   #4
sameyrasmea72
sameyrasmea72's Avatar
I am pretty sure it is very difficult to find a new one these days. The ones I have found have all been rebuilt. That being said I would buy a new/rebuilt one X3. I made the mistake of using a used one because I wanted it to look original/old paint like everthing else under the hood, and not long after I put $80 of r-12 in it the compressor went bad.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-04-2011, 07:17 PM   #5
Andyboy
Andyboy's Avatar
Thanks guys. New one it is.
Old 04-05-2011, 02:53 AM   #6
leddzepp
Moderator
leddzepp's Avatar
If you get a new one, I recommend an A/10 replacement from Old Air products. It is NEW, not rebuilt. The rebuilt A/6 will more than likely leak at the front seal. The 4 I went through did Just like Jason experienced above. The A/10 looks very similar to the A/6 and bolts directly to the factory brackets, and is more efficient. You can use R-12 or R-134. I finally put one in my truck , and had zero problems after that. A/C is not cheap!
You can get a rebuilt A/6 from any parts house for around $150...it will eventually leak.
I had a local shop source a new (NOS) A/6 compressor and it was $800
The A/10 runs around $350-$400
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 04-05-2011, 04:48 PM   #7
Wrenchbender Ret
I use used A-6 comp. all the time. They are so rugged you seldom get a bad one. You can get them anywhere from free to $35.
Wrenchbender Ret is offline   Reply With Quote
