Old 04-04-2011, 03:43 PM   #1
erikgto
Anyone got LMC's on door weatherstrip installed?!?
I bought the on door weatherstrips from LMC for both sides to try if they reduce windnoise on my '86s doors.
Now I really can't figure out how to mount them on the doors. I feel really stupid right now...
I know the weatherstrips need to be glued in place, but I really don't get the mounting tabs on them.
Tried turning them in every thinkable position and I still haven't found what I consider to be the "right" position.......
Maybe someone here has them on his truck?!? Pics wound be awesome.
Thanks, Erik
1972 GMC 2500 Sierra 350
1971 Pontiac LeMans Sport 400 GTO/Judge Clone
1970 Pontiac GTO 400 convertible restoproject
1970 Pontiac Bonneville 455 convertible
erikgto is offline   Reply With Quote
Old 04-04-2011, 10:00 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Anyone got LMC's on door weatherstrip installed?!?
You talkin' 'bout item #2 below? Looks like 2 different part #'s for left & right sides to me.
Haven't seen them on doors for a while myself but my old 74 heavy half had them. Junked that one out 13 years ago though.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-05-2011, 07:53 AM   #3
D13
D13's Avatar
79-81 only?
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-05-2011, 04:10 PM   #4
erikgto
Yes it's the part number 2.
Got both LH and RH pieces.
Even though they're not listed fo every year square I figured it would be possible to make them fit.
Square doors all have the same door frame IMO.
But I really don't know how they ought to be mounted......
Old 04-05-2011, 11:39 PM   #5
dmartin1
dmartin1's Avatar
i bought those.
"upper auxilary seals"........they required me to use weatherstrip adhesive(glue) and glue them on.
the weather strip on the cab didnt need glued from lmc,it had a duel you smacked it on and glue was inside,glued itsself.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-06-2011, 04:34 AM   #6
westie 666
westie 666's Avatar
Just cut the tabs off and glue em in place, I was told the are not needed.
Some one will correct if I'm wrong
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 04-06-2011, 03:30 PM   #7
erikgto
I know the weatherstrips need to be glued on.
It's the tabs on both ends that that got me so confused.
Just can't figure out what to do with them and where to put them.
Makes you wonder why they put the tabs there in the first place if you need to cut them off?!?
Old 04-06-2011, 08:19 PM   #8
78 Chevyrado
If you can, I'd cut off the tabs and just glue it. on my 87, I had that number 2 piece and the PO had put in the screws and the front screw contacted the cab when you shut the door. plus with no screw holes, the screw holes can't start rusting on ya later.
This is the best pic I have of my 87. I didnt pay them too much attention, as the PO installed them. I liked them though.
78 Chevyrado is offline   Reply With Quote
Old 04-06-2011, 08:46 PM   #9
Ger
Mine has them and the tab ends are screwed into the door, see if you have screw hole or screws where the tabs will line up
Ger is offline   Reply With Quote
Old 10-12-2011, 01:03 PM   #10
kikkegek
kikkegek's Avatar
I have just received these weatherstrips too. So I am curious how you ended up installing them Erik.
please share some pics?
kikkegek is offline   Reply With Quote
Old 10-12-2011, 11:05 PM   #11
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
I got them for my 77. I figured the doors are the same so I'll just make it work. I ended up just setting them aside because I couldn't figure out how they went either. Any way you turn them they don't seem to work. I doubt the trucks really need them though. I just put on the LMC "on cab" weatherstripping and it's already watertight.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-14-2011, 02:31 PM   #12
kikkegek
kikkegek's Avatar
these are not for water, but mainly for windnoise. with these one, the wind can not get into the space between your door and body and therefor will cause less noise at higher speeds...
