Old 04-05-2011, 01:42 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Small block ID please...
Just picked up a junk 72 blazer and need help decoding the engine. I can't see the casting, but the front numbers are VO515UPB. It looks to be a later model. Thanks for any help.
Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-05-2011, 02:10 PM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Small block ID please...
I don't see that one on the list at:
http://www.nastyz28.com/gm-chevy-cod...s-suffix-9.php
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-05-2011, 02:13 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Eric....can you recheck the suffix code to verify it's UPB???
I'm using this website to help me
http://www.nastyz28.com/chevy-engine-code-stampings.php
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-05-2011, 03:36 PM   #4
too much stuff
Roadtrip!
It looks correct to me.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-05-2011, 03:42 PM   #5
rsavage
rsavage's Avatar
Could it possibly be URB? That is an 83 350ci truck.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-05-2011, 05:34 PM   #6
too much stuff
Roadtrip!
Scratched it some more and it sure looks like UPB.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-06-2011, 10:24 AM   #7
too much stuff
Roadtrip!
ttt
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-06-2011, 12:54 PM   #8
bruceman1968
bruceman1968's Avatar
Could it be a 69 307 with 305 heads and intake? I blew up your pic and inverted the colors and I wonder if mabey thats not a B looks more like a 5 but that doesn't compute either. Also is that a little dot after the P?
I also looked at the casting stamp on the driver head and it looks close to O below, but not exact so I really don't know. O is late model 305, could heads and intake have been swaped? If it were me, I would pull that alt and wirewheel the pad. Then use machinest dye or paint on the stampings, then sand the pad with a flat block and fine sandpaper, then see what you get.
If this doesn't help atleast it will get you back to the top.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 04-06-2011, 10:03 PM   #9
too much stuff
Roadtrip!
A little more info. The number on the intake looks like 14057055
And it looks like UPB to me on the block. I think there are some other numbers below the stamp, but they are very faint.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-06-2011, 11:20 PM   #10
bruceman1968
too much stuff, Just found this on chevymania
http://www.chevymania.com/partsid/
Code Year CID Vehicle HP RPO Carb Comments
UPB 86 350 Truck 160 LT-9 4-Brl C-20 & C-30
UPB 90 350 Truck 210 L-05 TBI All Models, Van
Old 04-06-2011, 11:35 PM   #11
too much stuff
Roadtrip!
Since this has the 4bbl, i assume it is the 86 engine you listed. I think it is a fairly fresh engine that has sat for awhile. Now the question is what to do with it!
Thanks for your help bruceman.
Eric
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-06-2011, 11:53 PM   #12
bruceman1968
Eric
on one website I found intake #14057055 is 86 350 4v cast iron, and #14057053 is aluminum but I haven't found a second source on that. I think it's safe to say it's 1986 350. your welcome, Bruceman
