Old 04-05-2011, 02:16 PM   #1
hrnddy247
67-72 cab swap
just curious if anyone on here has tried to put a 67-72 front clip and cab on an 88-98 chev/gmc or if anyone has any info on going about this project or if its possible. any info or anything would be appreciated
hrnddy247 is offline   Reply With Quote
Old 04-05-2011, 02:29 PM   #2
CARZ1968
Bowties from Birth
CARZ1968's Avatar
Re: 67-72 cab swap
This was done on a 2000 chevy but would be the same amount of work on a 88-98,
http://www.sporttruck.com/techarticl...n/install.html
I have also seen 49 chevy conversions and a 66 chevy conversion on these trucks.Google 88-98 chevy front end conversion and click images and you will see many different front ends on chevy's. Some good, some
68 K10 Burb aka "da bomb"
72 C10 SWB Highlander
97 30th anniv. Z28 Conv
99 Chevy Crew 454
11 Traverse AWD
CARZ1968 is offline   Reply With Quote
Old 04-05-2011, 05:17 PM   #3
bucketObolts
bucketObolts's Avatar
Re: 67-72 cab swap
Conceptually it sounds cool but, im not too thrilled with the outcome. just doesnt look right to me but to each his own.
bucketObolts is offline   Reply With Quote
Old 04-05-2011, 08:17 PM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
Re: 67-72 cab swap
that's like taking a pinto front end and putting it on a 1969 Camaro things that might sound cool But in the end they come to me and they get scraped.All them 1980's Mini trucks I use to see them all the time all decked out Now NONE and the ones that survived wont Pass the EPA standered's
stsalvage is offline   Reply With Quote
Old 04-05-2011, 09:15 PM   #5
67/72junkie
Re: 67-72 cab swap
I think he means the cab and clip on the newer chassis.
67/72junkie is offline   Reply With Quote
Old 04-05-2011, 10:00 PM   #6
truckster
truckster's Avatar
Re: 67-72 cab swap
I saw one that someone had even kept the modern dash and interior, and they fabbed it all up so it fit the 67-72 cab really nicely. I think it was on this site, but I can't remember how long ago. That happens when you get to be my age.
truckster is offline   Reply With Quote
Old 04-05-2011, 10:41 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: 67-72 cab swap
Here is a couple with just the clip.
http://67-72chevytrucks.com/vboard/s...ighlight=grill
http://67-72chevytrucks.com/vboard/s...d.php?t=349692
LockDoc
Leon
Old 04-06-2011, 12:06 AM   #8
mr48chev
mr48chev's Avatar
Re: 67-72 cab swap
The best way to figure it out would be to put both rolling chassis side by side. No doubt it can be done if you want to do enough fabricating and enough trimming. It's how much trimming and or fabricating that are involved that is at issue.
It probably isn't any harder in the long run than putting one of the AD truck cab, nose and beds on an S-10 chassis.
mr48chev is online now   Reply With Quote
