04-05-2011, 05:25 PM | #1 |
timing headaches
65 305 v6. new plugs, wires, cap, rotor, points, condenser, vacuum advance, coil, running a holley 550 2brl. dwell set to 30, timing set to first mark. back fires through carb on acceleration. pulling my hair out, anyone have any ideas?
04-05-2011, 07:43 PM | #2 |
Re: timing headaches
if the timing is set right , then I would suggest it is the accelerator pump in the carb ..... It should start to shoot fuel the instant you start moving the throttle........
04-05-2011, 07:47 PM | #3 |
Just here to tinker
Popping through the carb is a lean condition. I would set the timing to around 6 degrees. Factory is 4 degrees. Also check that you don't have any vacuum leaks.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
