03-23-2003, 07:57 PM | #1 |
d-oh!
Throttle cable or rod?
Hey folks,
I'm curious what people are using for their throttle hookup from the lever at the firewall to the carb? I have a mid-70s 350 in my '65 C10 with a Holley 4bbl and at the moment am using a fabricated rod to control the throttle but am curious if anyone is using a cable. TIA
Sean 1965 Chevy C10 Fleetside | 350 4bbl | duals w/headers & Flo-Pros | 2004R with B&M 4sp shifter | 3.73 12-bolt Last edited by Balls McGee; 03-23-2003 at 08:03 PM. |
03-23-2003, 08:48 PM | #2 |
i am useing a cable i took it of of a 74. brackets and floor pedal i just redrilled the holes for the firewall mount and cut a square hole for the cables to go throught and its dune. took about a hours time .
if everything seems undercontrol your just not going fast enough
11 second pickup |
03-23-2003, 09:20 PM | #3 |
d-oh!
Thanks, you wouldn't happen to have any pics of your setup would you?
Sean 1965 Chevy C10 Fleetside | 350 4bbl | duals w/headers & Flo-Pros | 2004R with B&M 4sp shifter | 3.73 12-bolt |
03-24-2003, 03:17 AM | #4 |
I installed a 400 small block in my 62 GMC,
and had to put in a cable set up for carb. I like the feel much better. |
03-24-2003, 06:29 AM | #5 |
d-oh!
BG62, did you keep the stock level that controls the cable (at the firewall)?
I want to go cable too but am trying to get a feel for how everyone has theirs set up. Thanks
03-24-2003, 10:35 PM | #6 |
I was able to use the stock set up, peddle, linkage ect..
I took a small straight round piece of metal made a small opening ring on the top end of the piece. welded it on the top of the stock linkage that's attached on the fire wall. I then had to drill a hole in the fire wall. Ran the cable into hole in firewall,attached it to the piece I welded on through the ring, crimped the end of the cable at ring.then just adusted. I hope this helps im bad at explaining with written words. I'll try to get some picture's |
