Old 04-05-2011, 09:11 PM   #1
warden
Grafted Front ends for 53 GMC 1/2 Truck?
Ok, we've taken delivery of our project truck and looks like we may have to put a new front end on this puppy! So question is: "what front ends, from donor cars/trucks or new builds have people had good success with?". I'm leaning toward putting a camaro front end with 2" Z, which will slam it. But not completely sold on ride. Anyone have experience and pic's to share? Thanks!
warden is offline   Reply With Quote
Old 04-05-2011, 10:23 PM   #2
Kid
Kid's Avatar
Re: Grafted Front ends for 53 GMC 1/2 Truck?
do a search, there's lots of info on this, folks have had success with camaro's, G body (78 to 87), as well as S-10 frames. I used a 84 grand prix (G body) & it worked very well, & rides great. Then theres the standard mustang 2 kit's, they don't require as much fab work. I used to question the strength, but there are alot of them on the road so they must be ok.
Kid is offline   Reply With Quote
Old 04-05-2011, 10:44 PM   #3
tmoble
The Second Gen Camaro front is wonderful, but it's really too wide for an early truck. I'd look at one of the many Mustang II based solutions.
tmoble is offline   Reply With Quote
Old 04-06-2011, 08:19 AM   #4
Indian113
Indian113's Avatar
If youi can get the camaro frontend cheap enough you can buy narrowed Aarms and have less money in it than a MII. IMOP
Indian113 is offline   Reply With Quote
Old 04-06-2011, 09:23 AM   #5
blitz'd
vintage car junkie
blitz'd's Avatar
Re-build parts are expensive for those camaro clips. Unless you find one with decent bushings, ball joints, brakes, etc MII would be in the same ball park but less time consuming.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 04-06-2011, 10:00 AM   #6
jimig1
jimig1's Avatar
I have found that to be true it is just slightly more to go with a MII and they seem to be an easier install
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 04-06-2011, 11:38 PM   #7
quigman
I have done the camaro clip before and will not do it again. The cost savings was minimal and not worth it in the end. The MII is the way to go, all your sheet metal will line up and you will be done in a weekend. The front clip route takes a ton more time to rebuild, install and your measurements better be right or your sheet metal is off. Take your time and save you money and buy the right part the first time. THE CHEAP WAY RARELY WORKS OUT.
quigman is offline   Reply With Quote
