Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-05-2011, 09:36 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
How possible is it??
I have a dilemma... I really love the 81-87's, and want to go either high 11's or at least low 12's. I am definately doing a Big Block and a SWB. I'd like though to not have to butcher the sh!t out of it and make it impossible to corner in or take on a road trip. I am lookin at the vortecpro motors, and I definatly lean towards the upper 600hp engines... Is that just way too much torque? Is a well built rank sbc a better way to go? Traction and weight are the biggest issues right? What can you all recommend I do? Thanks!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-05-2011, 11:22 PM   #2
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: How possible is it??
look into the life of the engine if you plan on driving it on the street and freeway.
A 600hp small block might be good for 2 1/2" years
A 600hp big block will last for 5 years.
IMO if you run a big block and plan on hooking up.
Your looking at moving the motor back or your weight transfer will be 65% front and 35% rear.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 04-05-2011, 11:33 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
Well I definately want the engine to last! Transfering weight from the front to the back is obviously a large issue... I plan to do a fuel cell between the frame rails out back, and relocate the battery... More than likely slap on a glass hood as well... What other recommendations can you make C-10 Kid? Your ET is EXACTLY where I want to be!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-06-2011, 12:15 AM   #4
68 C-10 KID
Mean Green
A man sized tire & a set of adjustable shocks for the front, rear.
I haven't started any weight reduction, my battery is still up front. So my truck is a fat pig.
One of the 1st things once you get the motor combo, fuel cell and battery relocated is to scale the truck. Find some stored energy springs for the front. They will help to get the front to transfer.
I'm no good at any of this.
Super73 and some of these other heavy hitter have there trucks set on kill for the launch.
AKA MEAN GREEN.
Old 04-06-2011, 12:51 AM   #5
69GMC910
MOTORHEAD!
69GMC910's Avatar
Well it's safe to say that I cannot wait to start building! I look forward to the help and knowledge from everyone on this board! Best damn board on the internet for sure!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-06-2011, 09:42 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
LS motor + FI might help keep weight down and still deliver the power.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-06-2011, 09:01 PM   #7
69GMC910
MOTORHEAD!
69GMC910's Avatar
What is the build cost on an LS motor though? I can get 700hp for $7500 @ vortecpro... While I know his engines are all cast steel (heavy) parts, you can't beat the price/power ratio he offers as far as I know.. Please fill me in if I'm missing something!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-06-2011, 09:27 PM   #8
PGSigns
PGSigns's Avatar
Well the first thing you need to do is pick what the main use of this truck is. The motor that make 700 is not going to run well on todays pump gas and may make it hard to do the road trips you talked about. You can run the number you want on 600 real HP and make it on pump gas. Bolt on fuel injection will make it much more drivable and help at the track also. A good tranny and converter is needed and I would put a 9" in it with clatracs and let it eat. The suggestion on good front springs and shocks is a good one. A no ac and no power anything truck weighs the least. Some things we have done for years to get weight out are things like light weight seats, pull the carpet and remove all the padding and sound insulation and put the carpet back, a fuel cell that is only as big as you need like 12 gallons. A smaller battery, no tail gate, a pin on hood, roll pans front and rear. It all ads up and a 100 pounds is a tenth off the et.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-06-2011, 11:15 PM   #9
Super73
Super73's Avatar
Start by reading the suspension 101 thread sticky I started and have not finished. There is a lot of good info there. Once you read it, then feel free to ask me more specific questions.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-07-2011, 12:28 AM   #10
69GMC910
MOTORHEAD!
69GMC910's Avatar
Great, thanks Super73!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
