Old 03-23-2003, 08:00 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
shift knob
I got my short shifter for my blazer but can not seem to get the old black knob off the old shifter anyone have this problem before....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-23-2003, 08:01 PM   #2
Dreaminator
Dreaminator
Geez mine keeps falling off!
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
Old 03-23-2003, 08:40 PM   #3
Johns70
Johns70's Avatar
heat it with a little propane torch down on one of the bends away from the knob about two inchs down.heat slow because if you get it to hot the knob melts.heat for a little bit then stop and wait a few seconds, while pulling on the knob. the heat will transfer up the shift arm while your waiting and start to heat the knob allowing it to loosen and pull off. good luck hope this helps
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 03-23-2003, 10:37 PM   #4
MOTHERTRUCKERS
Put it in a pan of boiling water.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
