Old 04-05-2011, 10:42 PM   #1
jwgeorge
67 Truck with a 69/70 Core Support...Help!
OK, I have a problem with my truck, the headlights just don't fit right. After a little research here on the forum I find out that I have a 68 truck with a 69-72(?) core support and that the headlights/buckets aren't fitting with my 68 grille. I am not going to change my fenders or my core support. I have read everything, but am still trying to make any sense of it all, so my question to the forum is:
What are my options for a grille in this truck?
Can I go with a GMC grille?
Can I use a 69/70 grille?
Do I need to make my own custom grille?
Arggggghhhhhhh!!!!!!!!
1968 C-10 Longbed, 6-cyl., 4-speed.
832-584-1245
"You see, in this world there's two kinds of people, my friend, those with loaded guns and those who dig."
jwgeorge is offline   Reply With Quote
Old 04-05-2011, 10:56 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: 67 Truck with a 69/70 Core Support...Help!
Am I reading this right? Do you have 67-68 fenders and hood and a 69-72 core support?
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-05-2011, 10:59 PM   #3
jwgeorge
You are correct, 67-68 fenders, hood and a 69-72 core support. The 68 grille does not work with the headlights.
832-584-1245
Old 04-05-2011, 11:16 PM   #4
chevytruckluver
It will have to be custom then, a 68 grill wont fit a 69-72 core support. The hood latch and center support are diffrent. Do the hood and fenders line up properly? do you have any pics of this?
Trey
72 Short Step
Old 04-05-2011, 11:35 PM   #5
jwgeorge
Hood and fenders seem to align OK, big gap between the hood and the cowl, but the hood shuts and latches good. It appears that the headlight alignment seems to be the only thing out of whack. Maybe I can modify my 68 grille to clear the headlights, like trimming it enough to clear?
832-584-1245
Old 04-05-2011, 11:36 PM   #6
jwgeorge
I'll try to attach some pics of the fitment.
832-584-1245
Old 04-06-2011, 12:48 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Lemme guess, they stick out about an inch too far and are slightly off-center. You need to drill out the spot welds and remove the headlight standoffs from the core support. The early and late core supports are dimensionally identical other than these 'buckets' that are spot welded to them on the later trucks. The '67-'68 headlights mounted directly to the support. If you have an early '69 support, they have been known to still have the square holes for the headlights already stamped in them behind the buckets, otherwise you'll have to drill them yourself.
This is a pretty easy fix Good luck!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-06-2011, 11:40 AM   #8
jwgeorge
The headlights mount too far in towards the centerline of the truck and they are too high.
OK, so gringoloco, what you are telling me is that I can remove the 69/70 bucket mounts and the headlights will be able to mount directly to the core support in the 67-68 configuration?
832-584-1245
Old 04-06-2011, 01:07 PM   #9
Tmend
Tmend's Avatar
this is a 69-70 core support you can the brackets that hes saying to remove
this is a 67 core support you can see the brackets are missin hope this helps
Tmend is offline   Reply With Quote
Old 04-06-2011, 01:14 PM   #10
jwgeorge
Yep, That's what I have, the 69-70 core support. I am starting to understand that I can remove the 69/70 mounts and go back to the 67-68 mounting. This makes me feel better. Thanks Tmend for the pictures!
832-584-1245
Old 04-06-2011, 02:01 PM   #11
Tmend
Tmend's Avatar
glad to help
Old 04-06-2011, 03:44 PM   #12
Indyuke
I didn't know the 67-68 core supts are the same as the 69-72 supts except for this little detail. So if I want to put a 67-68 front end on my 70, all I'll need to do is change the hood, grill, fenders and remove these light brackets. No changing out the core supt?
Indyuke is offline   Reply With Quote
Old 04-06-2011, 03:49 PM   #13
John Fabris
TOTY 2006
John Fabris's Avatar
Do some more searching on here, I believe its not that simple to remove the 69-70 headlight bucket and bolt on the headlight, the opening is different and you have to cut it open a little bit and then still have to deal with headlight attachment point.
It can be done, but this is not a bolt in.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-06-2011, 04:45 PM   #14
jwgeorge
I had read somewhere in the archives that I may have to use the 69/70 buckets to a certain extent to mount the 67-68 headlights. I shall approach this project carefully before cutting off any brackets or mounts. I kinda wish I could find a set of GMC headlight buckets and a painted GMC grille, I like the 4 head light look.
832-584-1245
Old 04-06-2011, 06:00 PM   #15
chevytruckluver
Attachment 726262
Attachment 726263
Attachment 726264
Attachment 726265
they say pics are worth a thousand words, this is good to know. gringoloco is all over it. this place rocks
Trey
72 Short Step
Old 04-06-2011, 11:25 PM   #16
jwgeorge
OK, I pulled the grille out of the truck and it made it possible to adjust the headlights. So now I need to figure out how to make a grille for it. I think that I will convert to 4 headlights because I really dig that look. Here are pictures showing the mis-alignment of the headlights with the grille. Also I show the difference between the 68 and 69 headlight buckets, 68 on the left. The retainer rings appear to be different too, 68 on left. And a picture of the hoop located properly showing the mis-alignment. Oh well, I'll figure out something. Looks like I may have a perfect 68 grille for sale now.[IMG][IMG][IMG][IMG][IMG][/IMG][/IMG][/IMG][/IMG][/IMG]
832-584-1245
Old 04-06-2011, 11:26 PM   #17
jwgeorge
832-584-1245
Old 04-06-2011, 11:27 PM   #18
jwgeorge
832-584-1245
Old 04-06-2011, 11:27 PM   #19
jwgeorge
Trying to post the damned photos!
832-584-1245
Old 04-06-2011, 11:28 PM   #20
jwgeorge
832-584-1245
Old 04-06-2011, 11:29 PM   #21
jwgeorge
Without the grille.
832-584-1245
Old 04-06-2011, 11:29 PM   #22
jwgeorge
Headlight retainers, 68 on left.
832-584-1245
Old 04-06-2011, 11:30 PM   #23
jwgeorge
Headlight buckets, 68 on left.
832-584-1245
Old 04-06-2011, 11:31 PM   #24
jwgeorge
Everything fits well, except for the headlights.
832-584-1245
Old 04-06-2011, 11:32 PM   #25
jwgeorge
Headlight mis-alignment with a 69/70 core support in a 68 truck, up and inside.
832-584-1245
