04-06-2011, 12:12 AM | #1 |
A guy with a truck
Rally Wheel FAQ
Rallies, ralleys, rally's, rallys, rally wheels, ralley wheels, rallie wheels... Whatever you wanna call 'em and however you wanna spell it. These wheels, though never installed from the factory on '67-'72 era trucks, have managed to make their way onto a number of them and look just as at home here as they do on '73-'87 trucks.
This tutorial will focus on the three types of 5-on-5 lug patterned wheels that are available in the steel rally style, 6.5", 7", and the most common, 8" wide wheels. I am putting this together because I have seen questions frequently asked about them, recently needed some info myself and couldn't find solid answers, and just so happened to have a pair of each in my possession at the same time. There is a stamp on the inner surface of the hoop of each wheel that identifies it, but is not always accessible or legible, so I will detail some easy ways to identify the different sizes of wheels, as well as some other possibly useful information. Pictured here is a 6.5"(L) and a 7"(R)
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-06-2011, 12:14 AM | #2 |
A guy with a truck
Re: Rally Wheel FAQ
We’ll start with the most common, the 15x8 wheel. These were installed on probably millions of trucks between 1973 and 1991. They are easily identified by the 1.5" step between the inner wheel and outer hoop. The backspacing and width become problematic when installed on the front of lowered trucks, rubbing not only the fender wells, but also the lower control arms. They work well all on all four corners of stock trucks.
Specs are as follows: Mounting Surface: 8" Backspacing: 4.25" Front Lip: 1.5"
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-06-2011 at 12:17 AM. |
04-06-2011, 12:16 AM | #3 |
A guy with a truck
Re: Rally Wheel FAQ
Next up is the semi-rare 15x7 wheel. At least, they seem to be more scarce than the other two types. I am not sure of the origin of these wheels as an OEM application. I assume they were used on the ‘light duty’ ’81-’87 C10s, the same ones that used the 1” thick ‘big car’ brake rotors. They can be externally identified by the slightly smaller 1" step between the inner wheel and outer hoop. These wheels will help with the lower control arm and fender well rubbing issues common on the front of lowered trucks.
Specs are as follows: Mounting surface: 7" Backspacing: 3 5/8" Front Lip: 1"
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-06-2011 at 11:39 PM. |
04-06-2011, 12:18 AM | #4 |
A guy with a truck
Re: Rally Wheel FAQ
Last is the 6.5” ‘van rally’, so named because it is found primarily on full size Chevrolet vans, which, by the way share a ton of suspension parts with trucks of the same vintage. They are easily differentiated from the other two by an almost non-existent step between the inner wheel and outer hoop. These wheels can help with the rubbing issues at the fender well by tucking the wheels deep inside the fender, but at the expense of limited clearance at the lower control arms when using drop spindles.
Specs are as follows: Mounting surface: 6.5" Backspacing: 4" Front Lip: .25"
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-06-2011 at 12:28 AM. |
04-06-2011, 12:19 AM | #5 |
A guy with a truck
Re: Rally Wheel FAQ
I also like to install the 88-98 center caps and trim rings on mine. Here is an easy way to install the center caps- the rings just snap in place.
The rear of the caps will have plastic plugs in each of the posts on the back of them. Remove them with a flat-blade screwdriver and use a 1/4-20 tap to cut threads for screws. The holes in the wheel align perfectly with the holes on the center caps. You can do all five, but I just used three and some thread locker
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-06-2011 at 12:25 AM. |
04-06-2011, 01:51 AM | #6 |
Re: Rally Wheel FAQ
Great information, Thank You!
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
04-06-2011, 06:30 AM | #7 |
Re: Rally Wheel FAQ
Yes, Thanks for the info!!!!!
04-06-2011, 08:15 AM | #8 |
Active Member
Re: Rally Wheel FAQ
Still don't know why we don't have a general "wheel and tire" area for stuff like this. It would be perfect for threads like this, instead of putting it in a specific year area.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
04-06-2011, 08:15 AM | #9 |
Re: Rally Wheel FAQ
I smell a sticky!
Great right up. Thanks for sharing the info.
04-06-2011, 08:51 AM | #10 |
Re: Rally Wheel FAQ
Sticky
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
04-06-2011, 09:07 AM | #11 |
Restoration Virgin!
Re: Rally Wheel FAQ
Thanks for the informative write up gringoloco....I'll request it become an FAQ!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-06-2011, 09:20 AM | #12 |
Re: Rally Wheel FAQ
X2 Great info: THANKS!!...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-06-2011, 12:47 PM | #13 |
Re: Rally Wheel FAQ
Great info as I now have several different sets of these wheels.
04-06-2011, 01:05 PM | #14 |
Re: Rally Wheel FAQ
very good work !!
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
04-06-2011, 04:21 PM | #15 |
its all about the +6 inches
Re: Rally Wheel FAQ
awesoome info... and I did my centercaps the same way and love them over the potmetal stockers.
04-06-2011, 07:21 PM | #16 |
Re: Rally Wheel FAQ
Great info and very helpful. Thanks!
04-06-2011, 10:54 PM | #17 |
Re: Rally Wheel FAQ
can we extent to center caps and hub caps that will or will not work
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
04-06-2011, 11:21 PM | #18 |
67-72 parts collector,…
Re: Rally Wheel FAQ
1 million "rep points" to Gringoloco,... for this thread.
Excellent FAQ!
04-11-2011, 09:34 AM | #19 |
Re: Rally Wheel FAQ
I picked up another 5 lug truck ralley wheel Saturday at a garage sale for $5 ,just couldnt resist. I also found a tire and wheel co near me that sells the 3" wide beauty bands for $55 a set .
04-11-2011, 01:00 PM | #20 |
laying low
Re: Rally Wheel FAQ
Someone said the 7" variety seems to be rare. In my area they are more common and the 6.5" is the rare one. 8's too.
For what the new ones cost money can be better spent on used ones, have them blasted and repainted.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-11-2011, 02:40 PM | #21 |
Re: Rally Wheel FAQ
They all seem hard to find or a little pricey in my area .I found my 6 1/2 " van ralleys locally on craigslist for cheap .The 7" and 8 " ralleys I bought from another truck guy ,they were more expensive though. I bought a mixed set of 5 and 6 lugs on Craigslist with other truck parts fairly cheap but have no need for the 6 lug wheels. There is a sandblaster on my way to work that will blast wheels for $10 each so I drop some off from time to time when I have some extra change. I dont know what Im going to do with all of them but they will be painted and ready.
04-11-2011, 06:49 PM | #22 |
VA72C10
Re: Rally Wheel FAQ
super info!!!
Looking for a 67-72 swb or blazer project in or around VA. |
03-03-2013, 12:58 PM | #23 |
Re: Rally Wheel FAQ
Great info thanks.
03-03-2013, 11:00 PM | #24 |
Re: Rally Wheel FAQ
great info, I plan on getting a set of Rallies, and take of the weld draglites
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
03-03-2013, 11:33 PM | #25 |
Re: Rally Wheel FAQ
perfect,, thank you for your time!!
