Old 04-06-2011, 11:06 AM   #1
blazer2007
making my own bracket?
I need to build a bracket similiar to this one for a.o.l system but I,ll probably have to weld it together ,top onto side with gussets,will a 110 wirefeed welder be good enough and what thicknes do you think I should use
blazer2007 is offline   Reply With Quote
Old 04-06-2011, 11:08 AM   #2
blazer2007
Re: making my own bracket?
sorry, pic the top bracket on this bag
Old 04-06-2011, 12:14 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
That really depends on how capable you are of using the welder. I have welded some pretty thick stock with a 110 mig. I am not very good at making pretty welds, but they do hold up.
Those brackets are pretty cheap, it might be worth just buying them. Those pictured came from Ride Tech.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-06-2011, 01:57 PM   #4
Mkcustums
Mkcustums's Avatar
1/4" and yes about the 110, a 220 would be easier though...
If you are questioning yourself about the 110, maybe have someone else weld it up for you instead.
Mkcustums is offline   Reply With Quote
Old 04-06-2011, 03:08 PM   #5
blazer2007
Here is a better pic,does that look 1/4 in?I,ve be welding for awhile but I,ll tack it and take to someone with a 220.If I can get it bent is a bend stronger than a weld? I,m just trying something and a bought bracket just isn,t what I,m trying to do,is close but not what I need
Old 04-06-2011, 04:10 PM   #6
Mkcustums
Mkcustums's Avatar
Probably 3/16". Don't need to worry about getting it bent, a good sound weld will be completely ok.
Old 04-06-2011, 06:36 PM   #7
blazer2007
ok thanks MK
Old 04-06-2011, 06:44 PM   #8
Mkcustums
Mkcustums's Avatar
No problem! Is this gonna be on your truck?
Old 04-07-2011, 10:42 AM   #9
blazer2007
on my blazer
