Old 04-06-2011, 03:15 PM   #1
structures
structures's Avatar
mount location for computer and fuseblock
I would like to get some ideas of where you guys are putting your computer and fuseblock. Would you post up some pics please?
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 04-06-2011, 03:41 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: mount location for computer and fuseblock
Mine is the stock harness and it is on the DS inner fender. But if I had my choice, I would like the PCM in the cab and the fuse block on the PS firewall or inner fender.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-06-2011, 06:36 PM   #3
RaceAGMC
RaceAGMC's Avatar
I have a re-worked harness, my fuse block is under the dash, I made a mount. My computer will be on the firewall behind the intake manifold.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 04-06-2011, 09:18 PM   #4
TR65
TR65's Avatar
Here is how I did mine. I wanted easy access. This is a daily driver. Not concerned about a "clean" engine compartment.
The fuse and relay box is a Texas highway patrol surplus from ebay. It had all the relays and plenty of fuses to hook everything up just like OE.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-07-2011, 05:40 AM   #5
67C10BUB
67C10BUB's Avatar
I just used the factory plastic bracket and bolted it to the LH fender.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 04-07-2011, 09:23 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine is being located on the DS inner fender well, up where the horn on my 66 is. I considered "tucking" them into the inner fender, but I feel the wiring is safer IN the engine bay rather than being exposed to the wheel opening.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-07-2011, 04:43 PM   #7
structures
structures's Avatar
Guys thanks a lot I appreciate this and the links to your build threads.
TR I don't know what you consider clean but I think that looks pretty clean myself.
Clyde did you take any pics of your engine bay. I'm doing the stock harness rework myself, but I picked up a current performance fuse block to adapt.
Robert
1965 Chevy C10
Old 04-07-2011, 05:05 PM   #8
Clyde65
Clyde65's Avatar
yes, here ya go, now ya know what "not clean" is, right? this really doesnt show much, the computer was mounted with a stock tray and then bolted to the inner fender with rubber bushings for shock prevention or lessening rather.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-07-2011, 07:26 PM   #9
structures
structures's Avatar
oh man clyde take it down it's awful!!! dude that looks great I can't believe you're not happy with it.
Robert
1965 Chevy C10
Old 04-08-2011, 10:33 AM   #10
Clyde65
Clyde65's Avatar
I didnt have the time to "clean" it up when I had the old motor out. I would like to take the front sheet metal off and powdercoat the inner fenders and core support, and pain the firewall. but 1 thing at a time, and I dont have space for the job.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-15-2011, 05:47 AM   #11
CamaroChris
I'm going to mount my PCm in the engine bay. Probably on the driver side fender. I'm just worried about water and mud, but i guess it comes like that factory :shrug:
CamaroChris is offline   Reply With Quote
Old 06-15-2011, 09:52 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thats basically how I have mine. Water and mud shouldn't be much of a problem unless your off roading the thing. The PCM itself wouldn't care about the elements, as the the connections have the bolt-on water tight seal. Just make sure you isolate it (i used silicon pads) a bit from vibration.
Old 06-16-2011, 10:22 PM   #13
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Looks good!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 06-16-2011, 10:37 PM   #14
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
BR3W, Lookin' good man! I want that engine cover
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
