Old 04-06-2011, 07:44 PM   #1
sobayshortbed
sobayshortbed's Avatar
What oil pan to use if i want my truck to lay frame
I just picked up a gen IV 6.0 with a 6L90e trans, im tinking the pan and maybe the trans might be too deep to lay the truck out without lifting it and cutting up the floor for clearance. Whats your thoughts. thanks
sobayshortbed is offline   Reply With Quote
Old 04-06-2011, 08:48 PM   #2
c10seconds
c10seconds's Avatar
Re: What oil pan to use if i want my truck to lay frame
You'll need a pan from a 98-02 ls1 fbody car. Camaro,firebird,trans am. Pick up tube and windage tray will also be needed
c10seconds is offline   Reply With Quote
Old 04-06-2011, 09:23 PM   #3
Notch1988
Notch1988's Avatar
What about the GM Performance muscle car pan? You can get a new kit with pan, windage tray, pickup, bolts, dipstick for $150.
Notch1988 is offline   Reply With Quote
Old 04-06-2011, 10:32 PM   #4
sobayshortbed
the performance gm pan swap says its 7.75 in depth and i just measured mine on my gen IV 6.0 and its 7.75 also.
Old 04-07-2011, 06:00 PM   #5
kvn1011
Kvn1011
kvn1011's Avatar
Good info! Sobay
The muscle pan price is right on they need to come up with an equally priced fbody kit, it should be cheaper imho less material should equal lower cost... good ole supply and demand, I'm looking on ebay trying to run across one
kvn1011 is offline   Reply With Quote
Old 04-07-2011, 10:50 PM   #6
Hart_Rod
Hart_Rod's Avatar
What motor mounts are you using? I used the ECE setup and a Cadillac CTsV pan on my 69 Burb.
Hart_Rod is offline   Reply With Quote
Old 04-07-2011, 11:20 PM   #7
kvn1011
Kvn1011
kvn1011's Avatar
I have the porterbuilt dropmbr and mounts, ctsv should work too, I'm gonna hopefully get the dmember installed next week,
Old 04-08-2011, 06:39 PM   #8
sobayshortbed
Hrt rod, that looks good, nothing i hate more than the pan and headers hanging down well on my vehicles that is.
Old 04-10-2011, 02:26 PM   #9
19stepSide72
wanna be 67
19stepSide72's Avatar
just was wondering this exact question, Thank you for the info.
19stepSide72 is offline   Reply With Quote
Old 04-10-2011, 03:15 PM   #10
Hart_Rod
Hart_Rod's Avatar
Thanks!
Old 05-24-2011, 10:08 PM   #11
Notch1988
Notch1988's Avatar
Did you get the dropmember installed with the CTS-V pan?
Old 05-24-2011, 11:42 PM   #12
kvn1011
Kvn1011
kvn1011's Avatar
I actually got the fbody pan, but the muscle pan kit will work and is cheaper
Old 05-24-2011, 11:55 PM   #13
kvn1011
Kvn1011
kvn1011's Avatar
Check out post 232
http://67-72chevytrucks.com/vboard/s...79#post4677979
Thanks to rick at rocky point for the measurements, but I actually ordered my pan a day or so before I got the info from rick otherwise id have the musclepan kit, I think 135 was the lowest price that I found
Old 05-25-2011, 09:42 PM   #14
Notch1988
Notch1988's Avatar
Check out post 232
His measurement was to the ground though. What's the measurement from block to bottom of dropmember?
Old 05-27-2011, 12:17 PM   #15
1moretoy
here is my ls1 with the factory oil pan. Its perfect
1moretoy is offline   Reply With Quote
