wiper vacuum hoses
anyone know which hose and where each one goes coming off the back of the wiper motor. mine has 3 coming off and not sure which ones go to windshield sprayers and which one to motor vacuum???
Member #1049
Re: wiper vacuum hoses
All three are for the squirter, the larger one goes to the fluid reservoir the other two to the nozzles under the cowl
Ok, that makes sense....so it doesn't hook to any vacuum under the hood? Thanks for the info bud
Member #1049
Correct, no vacuum connections.. the wiper motor has a mechanical diaphram pump mounted on it (which usually are bad) and a liquid reservoir on the fender
If bad, are these hard to replace?
