GM Addicted
I need to order my tv cable for my 700r4, I found that bracket that i will use. Also found the tv cable. Now i am having a hard time understanding which throttle cable to order. I need to know what length to order and how to install. I sure hope i dont have to drill a new hole in my firewall just to install the cable or does it have some sort of washer that will fit the stock hole. Any one on here have one installed is it a fairly easy install. Any help appreciated thanks
![]() Lokar Throttle and Tv Cable Bracket for Edelbrock Carb Lokar Tv Cable
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Re: Lokar Throttle & TV Cable Need install help
I'm almost certain the throttle cable just goes through a grommet in the firewall. Installation should be a breeze....
Posted via Mobile Device |
GM Addicted
The factory one has the grommet built on the cable that snaps into the firewall.
I think you can get that grommet separately iirc. I got one for the el camino not long ago from Oreilly's
GM Addicted
wow cant believe no one has done an install with these cables. Kind of funny but alright
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage Last edited by 54Caddy; 04-07-2011 at 12:25 AM. |
GM Addicted
Bringing this back up still wondering about the cable will order it this weekend. Also how long should i get the cable if no one has any info i think i will do a write up or something might be some good info
![]() Join Date: Feb 2010
I just went to NAPA and ordered the cable for my truck. I went home, ripped the old one out and put the new one in. The hole in the firewall is square, and the cable has a square plastic piece made on it that snaps in the hole. No muss, no fuss.
GM Addicted
Dang nice man what length cable did you get??
GM Addicted
Have the p/n for the cable at all?
i just order a Lokar throttle cable and got it yesterday i order xtc-1000ht its 24" but you cut it to fit its really eazy, and for the square hole i used two s.s flat washers one on each side, because the lokar needs a round hole, I can post some pics tomarrow if you want
Ross
It's not what you buy, It's what you build |
Lokar offers a bezal washer part number 1031 that is designed to use on the throttle cable if needed. You can contact us toll free at 1-877-469-7440
GM Addicted
pictures would be nice anyone
#13 |
Here are some pics
#14 |
GM Addicted
that looks nice man. So if i order the 24" then it should fit fine after some trimming of the cable?
#15 |
Yeah its really easy to do
