Old 04-06-2011, 09:53 PM   #1
motiveauto
motiveauto's Avatar
Disc Brake Help!
I have a set of McGaughys drop spindles PN 6072 for the truck (65 with an 84front crossmember) and Im kinda stuck!
Are these spindles for 1.25" rotors only?
What years C10s came with the 1.25" rotors?
Thanks Again For the Help!
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 04-06-2011, 11:04 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Disc Brake Help!
the parts house will ask you what rear brakes you have... 2" rear brakes = 1" rotors, and the other... 2+" rear drum is the 1.25" rotor.. that simple
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-06-2011, 11:09 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
73-80 had the 1.25" rotors.
Some 81-87 had the 1.25" rotors.
Some 81-87 had the "light duty" 1" rotors.
Your spindles will use 1.25" rotors.
Just tell the parts guys you have a 73, and you will be fine.
Keith
Convert to disc brakes.
