Old 04-06-2011, 10:57 PM   #1
Andyboy
Andyboy's Avatar
Fuel pump still leaking
Well I replaced my leaky fuel pump but now where the hard line goes into the pump is still leaking. It tight but still leaks. Has anyone dealt with this problem? Getting frustrated and very smelly. HELP
Andyboy is offline   Reply With Quote
Old 04-06-2011, 11:15 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fuel pump still leaking
Yeah, I went thru this, I cant remember how I got it to seal up. Is it a pre flared joint or did you do it?..
I just kept loosening, tightening and finally got it to seal, I even tried a new fuel pump and a new hard line!
John
1999 Toyota Tacoma 4x4
Old 04-07-2011, 12:02 AM   #3
Andyboy
Andyboy's Avatar
It is pre-flared and its a new fuel pump and a new fitting. I'll try looseining and tightening again just sucks with that gas running down my arm.
Old 04-07-2011, 12:11 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Have you checked the line itself for a crack in the flare. I take it that it's on the carb side.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-07-2011, 12:14 AM   #5
Rudy67chevy
rudy67chevy
Rudy67chevy's Avatar
Don't forget to disconnect the battery first
Rudy67chevy is offline   Reply With Quote
Old 04-07-2011, 12:24 AM   #6
Andyboy
Andyboy's Avatar
vettevet It leaked real bad with the hard line so I cut it and ran a rubber hose half way down to the fuel pump with a new 90 degree fitting, but still leaks but not as bad.
rudy thanks for warning.
Old 04-07-2011, 05:43 AM   #7
cdowns
cdowns's Avatar
runnin the rubber line like that is a great way to burn the truck to the ground
Old 04-07-2011, 09:58 AM   #8
68gmsee
Active Member
68gmsee's Avatar
As vettvet mentioned check real carefully for a hairline crack on the flare. I had one that did the same and the harder you tighten the more it opens the crack.
You have to look real carefully at the contact surface for the crack or an uneven contact sureface.
68gmsee is offline   Reply With Quote
Old 04-07-2011, 10:20 AM   #9
custom1970
Member
custom1970's Avatar
I'm not trying to be a wise %*#, but did you try wrapping the threads with an over abundance of teflon tape? I had same problem, also try and get it as dry as possible, gas has a tendency to "thin-out" teflon tape.
custom1970 is offline   Reply With Quote
Old 04-07-2011, 12:09 PM   #10
Andyboy
Andyboy's Avatar
This might be a stupid question but how come some people don't like rubber hoses. I've seen alot of people use them and never had a problem. Just asking not being an a$$, just want to know.
Old 04-07-2011, 01:36 PM   #11
cdowns
cdowns's Avatar
i state my opinion based on over 50 years playin with old cars and the bad results i've seen by shortcut guys using rubber fuel lines rather than going thru the effort to lean the skill to craft a bulletproof hardline
Old 04-07-2011, 01:53 PM   #12
custom1970
Member
custom1970's Avatar
Rubber fuel lines are disliked because eventually they will fail (leak) which obviously creates a huge fire risk. You'll find that a lot of people on this site are very anti-rubber fuel lines and others who have no problem with them.
Old 04-07-2011, 02:04 PM   #13
dmack91
dmack91's Avatar
My understanding was that you weren't supposed to use teflon tape with flare fittings because the flare was supposed to be self-sealing- the threads only tighten the connection. Is that wrong?
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 04-07-2011, 02:36 PM   #14
Andyboy
Andyboy's Avatar
You are right dmack
I just tried to loosen and tighten a couple of times and with no luck s__t is still leaking. So with my hand full of gas and smelling like a gas station I give up for now.
Old 04-08-2011, 09:22 PM   #15
Andyboy
Andyboy's Avatar
Ok I'm back and started fresh. Man sometimes you just have to walk away from things before you break something. Well I went and bought a pipe bender and pipe cutter and some hard line. Hardline is the way to go period. NO leaks and the bending part wasn't to bad at all. Did I tell you guys that it didn't leak anymore. Well thanks for all your help guys. Man I love this site.
Old 04-08-2011, 10:42 PM   #16
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
When you want it done right.....(you know the rest) glad you got it!
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-08-2011, 11:13 PM   #17
Hubscrub
Cruzin
Hubscrub's Avatar
yea the looseing tighting thing worked for me after a few times glad you got it and i agree HARD line is the only way minimal rubber looks better and hard line is super cheap too.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 04-09-2011, 12:02 AM   #18
dmack91
dmack91's Avatar
Glad it worked out for you.
Old 04-09-2011, 12:08 AM   #19
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
On my friends truck we had the same problem comeing out the fuel pressure regulator. We tried teflon pipe dope and teflon tape. Still leaked. Then our millwright friend put on on a layer of dope, then tape, then more dope. The thing sealed!!!
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 04-09-2011, 07:52 AM   #20
cdowns
cdowns's Avatar
wont leak till all the crap disolves using toilet technology on fuel system bad idea
andyboy glad you got if fixed no more leak and now you have cool tools that will always be there for you to do it right
