Old 04-07-2011, 11:45 AM   #1
biohazardbill
Engine Cage
Are there kits for these or are they mostly a custom fab situation?
biohazardbill is offline   Reply With Quote
Old 04-07-2011, 12:01 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Engine Cage
Are you looking to stiffen the front of your chassis? If you are, you can do forward strut tubes with a front motor plate. This is what I did for my project. And, to answer your question, yes, it is generally a custom fabrication project.
Forward struts:
Cardboard templates:
0.25" thick 6061 cut out and mocked up:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-07-2011, 12:07 PM   #3
biohazardbill
Re: Engine Cage
Mostly I was thinking just for core support so I can remove the inner fenderwells. I havent got to the point of "needing" them yet, just looking for ideas for when I do finally get to this point.
Old 04-08-2011, 02:30 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Engine Cage
Custom fabrication! Whats your plans with this truck?
http://67-72chevytrucks.com/vboard/s...d.php?t=454248
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-08-2011, 02:39 PM   #5
biohazardbill
Re: Engine Cage
[/B]
I have the porterbuilt setup up front and also putting in a big block. Seeing the setup in the pic I submitted leaves everything open.
