A/C From a Donor Truck?
I really need to put AC in my 66 Suburban. I was thingking of going to a junk yard and getting EVERYTHING from a newer truck. All the parts from under the hood, and everything inside, even ducts, vents, controls etc.
Does anyone have an idea of what would be the closest fit to a 66? I know that there will be alot of fab work, and I will have to ditch my stock heater, but thats fine with me. Also the donor truck needs to be new enough to be R134. THANKS! |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: A/C From a Donor Truck?
I dont know of anything that would work, other than an aftermarket unit from either Vintage Air or Old Air Products or something like that.
I have the OAP and it works great.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Seems to me that since most trucks are roughly the same size, there must be something that can be retrofitted.
Only one way to find out.
I was going to pull the AC pump off a 73+ to convert to an air supply. I would think you could retrofit AC gear, but I've never had a truck with AC before. ![]()
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
I called a local dismantler and its only $200 for EVERYTHING! So if I can get something that would work, it would be GREAT!
What all is included? I'd be interested in seeing a parts list breakdown to figure out where stuff would fit.
I am going to buy the knee knocker vintage air unt for the cab, use all the other stuff from a 91 burb to keep the a/c cheap.
#8 | |
