Old 04-07-2011, 05:41 PM   #1
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Square Body LS swap guys
I am having an issue with my speedo. I have a 90/91 burb cluster and it is about 30 mph slow. The Tech 2 indicates 30+ mph and the speedo is indicating approx 5-8 mph. Any body have to use a DRAC with one of these? Any body have a good place to have one of these checked or serviced? Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 04-07-2011, 05:44 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Square Body LS swap guys
where is your speedo hooked up to? Vss off trans or right off the PCM?
If PCM, you think the gears/tire size is wrong?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-07-2011, 05:46 PM   #3
Jonboy
Slots go on anything!
I used the cluster in an LT1 swap, and it worked fine (once I got a good speedo). My first one, the odometer worked, the second one the speedo worked and the odometer didn't. I figured the odometer not working was the lesser of two evils. I talked to Bob about how he wired his with the LS swap, and it was running the VSS out on the PCM directly to the pin on the cluster; no DRAC. The PCM is the buffer rather than the DRAC. Sounds like a bad speedo. I work at a GM dealer, Speedometer Service and Specmo both wanted $200 to go through the cluster for repair. Cheaper to find another one in my case.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-07-2011, 09:09 PM   #4
Big Port Jimmy 6
Addicted to Rust
The speed on the scanner is seat of the pants right. So the gear tire combo in the program is right. I guess the speedo head is bad. The PCM is hooked straight to the cluster input. Jay
Current trucks:
Old 04-07-2011, 10:07 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
what about the gear ratio.. what program are you using?
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-09-2011, 06:51 PM   #6
Big Port Jimmy 6
Addicted to Rust
I had Justin at black bear tune it. I don't want to have the ability to tune it, or I will tweak it until it breaks. Jay
Current trucks:
Old 04-09-2011, 10:37 PM   #7
Stitch
Location: Where I come from, it's cornbread and chicken...
Hey Jay, I have an electronic speedo gauge cluster. I just might have to make a trip to abbeville for a weekend vacation. Whatcha say? Give me a call buddy
Stitch is offline   Reply With Quote
