Old 04-07-2011, 07:51 PM   #1
Dova
Dova's Avatar
Rochester Carb Rebuild
I have a Rochester Monojet carb off an 67 K10 250. I got a kit from napa westbay here in the pacnorwest and they ordered a kit 341B well open it up to rebuild the carb, my first rebuild of a carb and it's for a two barrel. Does anyone have the part number for the correct carb rebuild kit? The gave me 2-5194A just by matching the year and motor up. I can't go to the parts store wife is working the carb is disassembled in the dining room floor, she will like that one I know. So just curious if anyone has the correct part number.
Dova
Dova is offline   Reply With Quote
Old 04-07-2011, 10:28 PM   #2
LandonL
LandonL's Avatar
Re: Rochester Carb Rebuild
http://www.carbkitsource.com/carbs/c...ChevTruck6.htm
There you go, find your year, or look on the carburetors tab and get the serial number and find it on the above link.
Hope it helps.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 04-07-2011, 11:11 PM   #3
Dova
Dova's Avatar
Thanks that is the right kit and the one at westbay is 12.76 i believe it what he quoted me, it was under 13 there's is over 20. Westbay is local too. I was kinda worried about rebuilding a carb didn't know much about the internals but after taking it apart it doesn't look too bad. But we will see once i put it back on and try to start it. Do you use any gasket sealer like Indian head or anything on the gasket of carbs?
Old 04-07-2011, 11:17 PM   #4
LandonL
LandonL's Avatar
I didn't tackle the rebuild, I just bought the kit for our friend thats a mechanic. I'm about to start a rebuild on a '68 Rochester BV for a 250 six, on the gaskets I didn't see where he used any sealant.
250 L6 .030 over
Old 04-07-2011, 11:28 PM   #5
Dova
Dova's Avatar
I didn't think you would, but when i was taking the carb apart one of the gaskets definitely had some type of sealant on it. I work as a mechanic so to say on a submarine but it doesn't make much sense why one gasket and not the others.
Old 04-08-2011, 04:05 PM   #6
Wrenchbender Ret
The Monojet carb didn't come out untill 68. If you have one on your 67 it has been changed. There is a # stamped vetically on a flat serface on the fuel bowl. If you give this # to a good parts man he can get the correct kit from it. When you put it together work the throttle a few times & make sure the link from the throttle shaft to the metering rod does not work its way out. Sometimes you have to bend it in a little.
Wrenchbender Ret is offline   Reply With Quote
Old 04-09-2011, 01:03 PM   #7
Dova
Dova's Avatar
Sorry not a monojet a 1bbl
